Hi..Thanks for explaining more. I certainly never thought you were bashing CrazyTalk, but I was just curious when you mentioned that mouth closing was a tedious process.
Sadly because CrazyTalk works using just a single photo or drawing, if the mouth is wide open it will be very difficult to get a realistic mouth closed look using the "Force Close" button in CT6 or CT7. This applies even for professionals using Photoshop.
Ideally you should try to use a photo where the mouth is closed or only partially open for best results.
