By dermotwalsh300 - 14 Years Ago
I have beenaway from iClone4 for sometime. I recall editing clothing in photoshop but cant remeber how to do this. None of the iClone files seem to be compatible with PS. Also is it possible to edit props, for example the drumkit? Thanks
OK, solved the clothing edit, anyway to edit props like drumkits?
By martok2112 - 14 Years Ago
Hi, Dermotwalsh,
Apologies that you waited so long for a reply. I just now saw this. You can edit the images of the the drums in Photoshop by "launching" their diffuse material from iClone, if you have PhotoShop set up as your default external image editor. You just have to be careful, because the layout of the images in PhotoShop may be radically different from how it appears as a physical model in iClone.
