Program crashes every time I try to save a project
https://forum.reallusion.com/Topic136008.aspx
Print Topic | Close Window
By DrBeaker - 13 Years Ago
No matter what I do, when I choose to save a project, it opens the dialog box, I enter the file name, click save and it immediately crashes without saving. I didn't notice it until I had made four projects and tried to go back to edit one of them and it wasn't there.:w00t:
By avflinsch - 13 Years Ago
I was having the same problem too.
I tried adding a file extension (.ct7project) in the save as dialog, and it saved the file. After the first successful save I didn't need the extension anymore.
By sk_20120923070653617 - 13 Years Ago
I have the same Problem. Adding File Extension don´t fix the Problem...
Any Help?
Very interesting...I added the .ct7project extension to a test file and it worked. When I tried to save the next one, I didn't use the extension but yet it saved correctly!
GLITCH!!!
By Peter (RL) - 13 Years Ago
Thank you for the notification about this issue. The development team will look into this.
Have you tried using the "Add/Save As" button at the bottom of Content Manager to automatically save the project to your custom folders. This is the recommended way to save your content, including projects, in CrazyTalk 7.
thanks...that seems to work into the custom folder but doesn't solve the transportability problem (sending the file to another). The add/save button doesn't create a file of any type (and I have no idea where it is stored otherwise). Convenient, yet not convenient!!!
drbeaker2010 (9/23/2012)
All you need to do is right click the project icon in Content Manager and select Find File. The save location will then be opened and you can copy/move the .ct7project file as required. :)
i have made the OSX Update to 10.8. Now the .ct7projekt Workaround work for me.
Under 10.7.x it don´t.
Peter, Thanks! Works very nicely.
You might want to also address the Save As... issue. If I click the + to add the project to my custom folder then try to quit, it asks me if I want to save the project...which I just saved. If I choose 'yes' then i end up with a copy in yet another location (than where the "+" button saved it).
Thanks again!
Brad
By don.sherman - 13 Years Ago
I saved the file to a different folder and it solved the problem completely.
was driving me crazy, now it's all good. no more crashes.
