Importing objects from other projects
https://forum.reallusion.com/Topic130306.aspx
Print Topic | Close Window
By torresroberto - 14 Years Ago
A great thing for CTA would be the import functionality from other projects, let's say that I have done a complex animation and want to import it into another project without having to do all the hard work I've done before.
An import functionality would give a huge value to CTA and easyness to my project! ;)
By AverageJoe - 14 Years Ago
Save it in the project you created as a seperate resource (character, head, prop, animation, etc...)... Then it's available in your new projects.
http://www.reallusion.com/crazytalk/animator/help/animator/pro/09_Timeline/Collecting_Expression_or_Motion_Clips.htm
Those are too many steps to be done, instead an import feature with fewer clicks would be much better! :D
torresroberto (7/26/2012)
Sorry, I disagree... If I'm creating an animation that I know I'm going to want to re-use, saving it as a specific motion makes much more sense to me, because I'd be building a linbrary of re-usable motions. To import from a scene that already has motions (but not saved as motions) would be far more tedious to import, especially if that complex animation was made up of smaller animation segments. No, when you create your complex animation, save it as a re-usable animation. Problem solved.
I totally disagree with your statement.
So many clicks for you ( Let's say 10 ) are better that doing 3 clicks?
A functionality like the one I'm mentioning it has to be devised, created and done by an IT person, one who sees the benefits for all users, thinking wisely for the benefits of the most rather than the benefits of the few.
torresroberto (7/27/2012)
3 clicks? Uh, I don't think so. Complex animations will be made up of multiple animations and keyframes. To import, you'd have to open the project and list all assets, and all animations per asset. Then the user would have to go through said list and select the ones they wanted/needed which would then have to be "imported" into multiple objects into your current project and place them appropriately. It's be much easier if the user showed some foresight and saved the assets they want to re-use in another project. it is afterall why you can save assets out as individual assets (props, characters, animation, etc...). For re-usability. An import process isn;t needed at all.
By Peter (RL) - 14 Years Ago
torresroberto (7/25/2012)
Thank you for the suggestion. This has been passed to the CrazyTalk Animator team for consideration.
