By wendyluvscatz - 14 Years Ago
not into Vocaloids, I use Myriad Melody assistant virtual singer but I downloaded MMD because it is free! I download a lot of free animation crap because it is free! any way, not finding the English version of PMD editor I settled for the Jap one and got a rigged Daz character via Carrara as a directX file into it. by pure trial and guess work it IS ENTIRELY IN JAPANESE!!! :w00t: cannot figure out how to get a rigged model out though for retargetting in 3dx5! just static props and figures may not be possible but I would not know BECAUSE IT IS ENTIRELY IN JAPANESE!!!!! dunno if the .x export is infact rigged but Carrara does not detect the rigging or just an object anyone else used this program?
By hirospot - 14 Years Ago
Hi Wendy, Just quick info for you, available MMD tutorials in English are listed here.
I'll also try to find out about your question. Hirospot
thx for that link Hirospot, looks more promising than the ones I have seen. the rigging I did get into MDD had no ik restraints and just stretched the mesh, most things inc iClone pipeline exports just get the yellow triangle with a ? in it. must grab the latest Blender one day, that might be the .x file link needed. at least it is in English! I can get props in and out.
iClone definately run rings around it but the bullet physics looked as though it could be cool. I just like collecting freeware for the sake of it! :hehe: and the Anime figures were cute but since they have copyright restrictions even on rendering, no point in rerigging them in Carrara to render in iClone or I would!
Hi Wendy,
This is the second quick info, PMD editor Tutorial in English is here. Please check.Hirospot
I bookmarked it. this appears to be quite a powerful little free program allowing rigging within it, pity the export/import options are limited to directX. I might play with it more later, thx for the link, bit too overwhelming at the moment, only learnt of it yesterday.
I was wondering how MMD characters can be transfered to iClone and here my new report for pipelining MMD characters to iClone.
Several freewares such as ColladaExport Plugin for MMD and FBX converter were used, then .x file was not needed.
Converted MMD characters can play with iMotion, however, motions designed for MMD characters, converted to BVH format by freeware, do not work properly in iClone at this moment.
Complete tutorial "Using BVH motion converter" with all JPGs is appreciated.
Hirospot
that is cool, will have to look at that collada plugin! I was hoping these cute characters could be brought into iClone! your tutorial is very well put together, who knows, MikMiku fans might start using iClone too! I certainly can see vocaloid voices being used with iClone avatars and others once they get the facial animation for imported characters working. I already do it (virtual singing animations) with Myriad Melody assistant virtual singer! in Carrara, Daz studio and Poser as well as iClone, the only reason I have not shown much interest in vocaloid is I find their site too hard to follow due to language barriers or I might have bought a voice or two already.
I imported the fbx into Carrara as the bones were huge in 3dx5 and renamed them in English to make it easier for me while I was there ;) added spring to the unused bones, worked on the skirt (which I lifted to avoid leg intersection, a lot of those anime videos show panties so thought it was ok, she has titties so is an adult!!!) the hair did not want to spring though which was a pity.
need uncopyright restricted MMD dance models though so I can do videos! I made sure I acknowleged the copyright and stated it was a test so hopefully fair use, if informed otherwise, will just remove it.
By sharad.inc - 14 Years Ago
hirospot (7/19/2012)
Hirospot
Hiropost, Have you tried using the 3Dexchange5's BVH conversion ability to map the the two rigs and then export the BVH as iMotion?
@sharad.inc Thank you for your question and very sorry for my delayed response. It had been very funny that the MMD characters converted to iClone Non-Standard character showed right T-pose and seemed dancing nicely in iClone, but when they bowed, they did to backward direction with imported MMD iMotion file.
It took time to find out that the reason was the difference of Coordinate system between MMD environment and iClone motion system. When exporting the MMD motion with BVH format, Left-handed coordinate system is to be adopted for 3DXchange Motion Pipeline. Here is the latest report of MMD motion conversion for iClone. Sample video (MP4).
Hirospot
Sugoi desu! (=Brilliant!)
By Dreamcube017 - 14 Years Ago
Whoa that's pretty neat! I remember seeing MMD a while ago..
Oh and Wendy, there are English vocoloids. I think one is named Sana or something. Prima is an opera one. The JP ones are only more popular because they have anime characters... although I think Sana (Sonna) has a character as well.
Please find my latest report regarding conversion process of one of the newest VOCALOID character found in the DVD-ROM attached to the MMD Magazine#3 in Japan. Ice skating blades are attached to the converted character for fun. (MP4;3.7M)
Thank you, Hirospot
Hirospot, I tried the spring modifier with some success on the skirt, not so much on the hair, mainly due to my ignorance on the correct parameters for gravity, bounce etc in the script to get the desired effect: my hair either just wobbled or sprung around madly (I tried looking at Wil Veeke's hair pieces for example for reference but it seems the boning etc of object used is also a variable). the horse avatar tail spx script as pointed out on this forum is a good starting point. export it from the horse open it in notepad and rename the bones to exactly match the ones you wish to add spring too then save it as all files unicode spx, I found it does not actually matter if you give it youcharactersname.spx or anothername.spx import it, it will take a while to show or may need to be reimported, iClone needs to think about it for some reason.
the issue is, importing characters into Carrara to rename bones destroys the smoothing but iClone cannot apparently read Japanese characters as bone names click to view on photobucket
so the spring modifier ignores the spx file.
okay, I renamed the bones in Carrara and found smoothing the model mesh in the vertex room kept the rigging
the renamed bones are recognized by the spring modifier.
Hi Windy, Thank you very much. Your instruction for Spring Modifier was great! Helped with your indication, Ponytail on the new MMD model was started responding to the SPX data. Here is the latest report referring to the SPX Spring bone settings for the stranger character. By defining target bones for Ponytail, hair, and Neck frill in each individual SPX files, these parts responded to each SPX parameters when imported to the project.
Short video for showing the SPX effect, their current parameters in my test may not be so perfect at this moment but the process in the report will be applicable to other MMD models.
Please check: Test 1 for Ponytail only and Test 2 for Hair and Neck Frills also.
It was observed when several settings were changed and imported one by one for the better effect, primally imported SPX data seemed to remain in the project file once it was imported, even if that SPX data was not shown on the file saved by Export Setting.
Thus, once one SPX file imported and want to modify the effect, I needed to repeat refreshing the current project with all the current SPX spring settings in the screen, then call the original project again for new import of the next SPX file. It seemed inconvenient for stranger characters to determine the adequate SPX parameters in a short time. There seems no visible indicator for Spring Effect settings on the Timeline Track List. I need to examine more on the relations between SPX data prameters settings and the expected effect on the screen, together with hoping how to make individual adjustment of spring effect for movable part on the character in realtime. Thank you again for your guidance this time.
Hirospot
Hi,
MMD characters are provided with extra bones and bone mapping tool in the 3DXchange is not fully expanded for these yet.Firstly, swing movement was realized by assigning the SPX parameter for Spring Effect to these extra boes in MMD character, however, it seems rather different from natural movement. Then, expressions by Flex method is told as the better solution as Flex Base, cloth and hairs are available in iClone Props. So, MMD characters could be better expressed as one of such iClone Props. Live Animation (Free MMD tool) can generate dance movement with characters hair and cloth. With the FBX Export feature in the tool, this movement was simply imported to 3DXchange, then, transfered to iClone as Props without being characterized in 3DXchange. By applying the same dance motion to iClone Flex type Character, MMD Props also can move in the same way.
Please find my latest report and short video (MP4:8.3M).
Thank you for your attention. Hiro
yes, it is a pity some of these extra features are lost by converting to non-standard characters, I believe the Max pipeline allows more of it to be accessed while still creating characters using iMotions. I can import even facial animation etc on characters rigged for it if they are props but you lose this option retargetting, spx was the only thing I could find that at least accessed some of the unrecognized bones, the much desired "third panel" would help solve this. I have never gotten flex to work myself on imported props.
Hmmm... This is really useful. I wonder... How is it that LiveAnimate can actually map the animations onto any character? Can animations from other characters be brought over? I really would like to use the iClone animations on some of those characters... darn, if only you could specify which bones were flex or springs in 3DX... I'll have to give LA a test, seeing as flex doesnt' seem tow rok.
By Illustrator Cathy - 14 Years Ago
I've added this to the Wiki under Misc. iClone 5 Tutorials.
Cathy :hehe:
make sure you put Sw00000p's tutorials in your Wiki too! I think he is feeling very unloved and needs hugs! ;)
I already have swooops in the Wiki. :cool: The problem is he needs to MAKE MORE TUTORIALS. :w00t:
Cathy :hehe:
Thank The Universe for Clone Bone my friend! I couldn't create a rig if my life depended on it!:w00t:
LOL
Cathy :hehe:
I've created simple rigs from scratch before... and it's not TOO bad, but I'm no pro rigger.
And as to retargeting ALL the bones... uh yeah... some of the bones don't have places to put them... the facial bones have no place to be targeted. I don't see why you'd LOOSE them in iClone though. You should still be able to move them... you might have to have a script for them though.
Also there are all those bones for clothing to have dynamics and stuff. Where do we target those... oh wait, we don't.
I can retarget the bones, but it'd just be so lame to lose all those dynamics and facial animations. That's just too much. I wish 3DX could have more of the features that the PMD Editor has.
Sooo... I started looking at Live Animate. It's pretty cool how I don't have to go through PMD and FBX converter... but MAN it'd be awesome if I could rename the bones..... like you have no idea. I know I can do it in C4D or something, but that's just one extra step. In MMD, the bones have English names. (The ones for Miku do anyway) How come they don't when you export them?
Is there a way to rename them in LiveAnimation or 3DX?
Thanks.
Ok when I say I've done simple rigs int he past, I don't mean I've just taken a BVH and skinned it... I mean I've completely set up the bones from nothing. I hand placed all the bones in the character I was working with, then skinned... THEN weightpainted to make sure they deformed correctly. What is the difference between that and rigging? I even set up IK chains.
Now here's the thing.
I KNOW I can bring the character in as a prop with ALL of the animations intact as long as they're bone based. That's NOT the problem.
The problem is I want to use the iClone motions on these characters WHILE still maintaining their dynamics.
If that's not possible without totally rewriting the SPX or flex file or something, then I'll just animate them in MMD or something and bring them over like that.
If they just had like a spring or flex editor where you could assign bones and see how they work that way, that'd be great... YES I know there's something like that in Max. I've seen the white papers... I've still got my student version and honestly I may just go in there JUST to do that... possibly... but then possibly not... depends on how non-lazy I feel. xD
But thanks for pointing that out. Totally forgot about this even though Hirospot mentioned it like a page or two ago.
I have used the spring modifier spx script on the bones as you saw on my video. you need to rename the bones though as it does not read Japanese characters, can do that in my case in Carrara but can use any 3D app with fbx import/export but not apparently 3Dx5 pipeline. flex would be better but I don't think I can do that without Max.
To Wendy.
Hmm. I've characterized the character WITHOUT renaming the bones... so all of the JP names are intact. The reason I did this is because all (most) of the MMD characters share the same names, so I now have a profile... and I have another one for a JP game that has a bunch of characters that can be exported to MMD. So they can be exported too. Their naming convention is a bit different, but I've made one for both... and the names are in JP. However, I might have to make the spring names English for the .spx file. That shouldn't be a problem as none of those bones are used in the initial characterization. So I can rename those with out a problem sense iClone's main animations won't be bothering those bones... I think I can even bring in the facial stuff that has bones... but I'm not sure about that yet.
One thing I wish though is that you could modify the T-pose of the character WHILE in the middle of a test animation because sometimes you just don't know how it's going to look until you start testing it. So you end up having to go back and forth. I'll put this in the suggestions thread. Shouldn't be something too hard to put into the next update.
Thanks Sw00p. If I have some time, I'll look into that flex stuff in Max. ... Or I just had a crazy idea where I animate it in iClone, export it back out and see if I can get it into either LiveAnimation or something else and see if I can get the dynamics back... somehow though, I kinda doubt it.
By peggy23 - 14 Years Ago
help how to import vmd motion file from MMD in LiveAnimation and export the motion file to use in iclone
Hi, Just revised my Pipeline Test report #9 (MMD Model to Unity) in which Custom motion such as BECKY_PANKING in LiveAnimation was adapted.Here some findings: 1. Scene Tree By using PMD Editor with Collada Export Plugin and Autodesk FBX Converter2013, 3DX5 can show better notation in Scene Tree. 2. Material 1) When FBX enbedded texture is imported to 3DX5, all Specurar value shows 100 which need to set to 0. 2) When Model has Opacity setting in 3DX5, Transparent/Diffuse is to be choosed in the Shader in Unity Inspector view. 3. Motion 1)Any license free characterized MMD Models, plus Custom Motions imported in the 3DX5 Motion Library and Performed can be exported into Unity via 3DX5 pipeline. 2) When Motion Clip is attempted to change in Unity, Model need to be in T-posed. Please find my revised report here. Demo video in MP4: 5.9MB
Thank you, Hiro
To peggy23, Please find my revised report 5, hoping it might be helpful.
Thank you, Hiro
Thanks Hiro. Much appreciated.
I've looked though a lot of your reports and they really do shed some light on a lot of things.
I've been wanting a lot of anime characters and the comgination of MikuMikuDance and this thing I found called 3D Custom Girl work rather well. I have to rename all the 3DCG bones to English in the PMD Editor, but that'll be easy, just kinda long.
Only thing that's really slowing me down is that iClone can't take faicial animations and I'd REALLY like them to have this feature... ohterwise I'd have to export a bunch of different versions of them with different facial features... that's no fun. So I'm stuck waiting on this update until I come up with another solution.
At first I had the idea of importing them back to MikuMikuDance, but then realize I'd have to do twice the work to get it to work right... or maybe I wouldn't not sure.
But I know that if 3DX FULLY supported JP characters, It'd takea LOT of hastle off of things.
Hmm... now if only there was a program to easily make lots of anime guy characters... gee......
Thanks again.
By hirospot - 13 Years Ago
Hi,
PD (Public Domain) tool with resources for MMD is available and can be used in iClone as Mob characters. The PMCA (PMD Mob Character Assembler) can export .pmd file after combining several premade parts on a boned human body.PMD importer and Exporter is available for Metasequoia(3D tool) when more models and parts are needed. Only a base model with parts provided in the PMCA was used in my test. Please refer to my latest report. PMCA Mob models Demo MP4:3.8MB, no sound.
Thank you, Hiro
Hi, This demo video (Lily& New Friends) is made for my practice of Bone Mapping work in the new 3DXchange5.4 applied to the MMD model with many Extended bones.
First Greeting part in the video is made by CrazyTalk6 as I'm not familierwith whether transfering of Facial morph data of MMD model to 3DX5.4 or iClone is possible or not.
Please also find the latest report #11 here.
Thank you, Hiro
Hi,
Here is my latest report#12 in which Bone mapping was applied to the MMD Furisode (Long Sleeve Kimono) Model ONIKO.
Demo video:ONIKO in iClone5.4
iClone5.4 64Bit in Bin64 does not open somehow, and my work had to be slowed down severat times as NVIDEA Display Driver had stopped operation when editing the motion details in the Timeline went to complicated.
Anyway, it was time consuming and not satisfctory to make synchronizing the dance motion to the free music manually, hopefully sound waveforms shown in the timeline.Thank you for your attention. Hiro
By hirospot - 12 Years Ago
Re: Motion Tracing & Facial Morphs of MMD Model
Two Reports and Videos with MMD Models have been issued.
Report #14 & Demo Video (English) Motion Tracing of dance music in iClone5.
G5 Character was used for the motion tracing and then created Motion Plus data was applied to other MMD Models in iClone5.
Report #15 & Demo Video (Japanese) KARAOKE version for another MMD Model with the same dance music.
By using PMDEditor, each Facial Morphs in a MMD Model was saved as a PMX file which was opened in PMDEditor again to export as DAE format. Then major Facial Morphs were imported into 3DX5 for Viseme expansion. LipSynching and Facial Expressions were manually adjusted in the iClone5.
Thank you for your attention, Hiro
By emreboz34 - 12 Years Ago
hello . i need miku dance motions. Are you could e-mail me at dance Motion :) Please
Hello, emerboz34
It is not recommended to use e-mail to send Miku dance motions as their file sizes might exceed the regular mail servers capacity.
Many Miku dance motions are available on a several web site now, I'd rather like to tell you that you visit the site like this: deviantART-Motion Data Index A-L
and find your favorite one by yourself.
The site has listing of motions and you can preview the video before you go to download step . If you intend to use the Miku motion in iClone5, you need other tools and step to convert the file format before importing to 3DXchange, as your downloaded Miku motion has .vmd format.
Please check my test report #4 and #5 for more details. Here
Disney Frozen: MMD Elsa Let it Go in iClone5 (Test Report)
Meny user videos have been created by using MMD Elsa models. Her motion in the movie was traced by MMD pro and listed on the DL site.
This test report explains how these MMD Elsa and the motion are converted to use in iClone.
Thank you, Hiro
Disney Frozen:Let It Go Piano Player & 【MMD】 funassyi in iClone (new video)
The MMD Piano in the video has 88 boned keys and included in the Midi2VMD tool made by mqdl. The key motion data, originally .wav format, was imported to 3DXchange through 4 different conversion steps.
MMD funassyi (Japanese Human Mascot Character) performs a part of Frozen movie motion by the Piano Player.
Thank you, Hiro
By planetstardragon - 12 Years Ago
really enjoying your work Hiro, great stuff!! :cool:
Hi, I was hoping to proceed the facial animation work for MMD Elsa in iClone5 Timeline, however, I gave up to continue because of frequent crashes in my PC environment. Then, I attempted to use CrazyTalk7 for her Facial animation, it is stable and creates .CT7script.
Unfortunately, .CT7script seems not compatible with previous .CTS which was used as a Facial Animation Pipeline in CT6 with iClone.
Here is my latest report and video.
Thank you, Hiro
By hirospot - 11 Years Ago
Hi, This is not a MMD character, but here introducing Unity game heroine 'Unity-Chan' performs in iClone 5.
Unity Technologies Japan has created her and her use is open to anyone under the agreement and guideline here.
Please check my short video and work report in Japanese at this moment.
Thank you, Hiro
Kyun! Vampire Girl by G6 Heidi, BGM in Japanese
Test Video of 'Kyun! Vampire girl' which Motion Data was converted from takane_vampire.vmd to BVH in LiveAnimation, then converted to iMotion in 3DXchange5. The Heidi motions has been found as symmetrical to the original in the conversion process. Please find my test video of 8,000 frames: Here Basic report for using G6 Heidi in iClone 6 DX9: Here
Japanese song 'Kyun! Vampire Girl' was used for the video which motion was played in frame by frame mode, then baked before final rendering for video. When iC6 DX9 crash happened in realtime mode, it could not be recovered because of memory hang-up. Lots of large RLAxxxx.temp files (approx.1GB/file, total 20 to 30 GB in few hours) have been created in the Drive which pressed the HD capacity seriously.
Hiro
By emreboz34 - 11 Years Ago
hello. How do I convert the VMDmotiond to bvh ? What program can I use . Please help
iClone Music Practice: 'Menuett' by Piano Player (Demo Video), (Related Report)
MMD Piano Player with 88 keys has been converted for iClone use as iProp. Piano sound 'Menuett' in Midi format is also used to drive the Piano Player Key before importing into 3DXchange.
The Demo Video was made with Robo Dog_A and rendered in Preview quality to get shadow flickering effect in IC 6 DX-9.
Thank you, Hiro
By mark - 11 Years Ago
WOW! That was a lot of work! VERY COOL!!!!!!:D:D:D
By animagic - 11 Years Ago
I have to check this out. I've always hoped for MIDI controlled-instruments in iClone! :cool: Thanks for all your research work hirospot! :w00t:
Hi, The sample data used in my report are available in the page. (Here) One zip file (1.98MB) contains following 7 files. menuett.mid:4KB menuett.mp3: 906K PianoPMDout.vmd: 20KB pmdGRAND.dae: 1.4MB pmdGRAND.fbx: 930KB pmdGRAND_menuette.dae: 1.4MB pmdGRAND_menuette.fbx: 930KBThank you, Hiro
iClone 3DXchange 6 Pipeline: Touch & Try ( Report ) Please find my latest report for 3DXchange 6 Pipeline in which MMD Ribbon is used with custom Heidi. She plays in the 3DX6 with my facial morph added in the Morph List under Expression Editor.
 MMD Ribbon was converted to FBX with the mesh modified, imported to 3DX6 then spring effect was applied to 15 bones, exported into iClone 6 then attached to Heidi hand as iProps. MMD Ribbon made by やん(yan) for Rhythmic gymnastics, has been introduced at the BowlRoll. Hiro
By Dreamcube017 - 11 Years Ago
Wow Hirospot. Glad to see you're still doing stuff.
I've been using your guide a lot to get characters from 3D Custom Girl into iClone as they import nicely to MMD. I'll have to check this piano thing out. Thank you so much for sharing.
You Rock My World: Chuck or Mason (Short Video) (Report)
MMD Dance Motion (You Rock My World), converted to iMotion (Report #21) and applied to G5 Chuck and G6 Mason. Characters voice were created by using AVATAR TTS ON-DEMAND. The Video is very short, but the Timeline Editing became very stable on the new iC6 (on my new PC). Please also refer to my Report for the Video. (URL) Thank you, Hiro
Hi, Lots of excellent Character models and motions are available in the MMD world for free, however, not all models can succeed the dance animation in iClone. Here Introducing the MMD Model "Ca(Shii-e)_wafuku_mmd" as she was succeeded as Dance Prop and iAvatar for iClone Use. Please check both models dancing in my Video and the making Report.
@ emreboz34 The Program and the process for converting VMD Motion to BVH is shown on the above report at Step-B.
(Other past reports are listed Here.)
Thank You, Hiro
By hirospot - 10 Years Ago
2016 New Year Greetings: iClone Chimp & MMD Rakko: Very Short Video made by improved iClone6.3 Timeline Editing. TTS ON Demand Voice is practical. Report Listing http://hirospot.web.fc2.com/index.htm Short Video https://youtu.be/t0_7pws_rg8
Thank you; Hiro
By Anna Mironova - 10 Years Ago
Could you please help me to find out what am i doing wrong Convetrering character through blender pmd plugin all bones are works fine, face expression editor too but i can't appoint any extened bone its just not active
By wendyluvscatz - 10 Years Ago
The hair is mapped to the head You need to map it to the body then use extend bone You can do this using the options under the retarget window
duplicate
yep! you are right :-) tried to put my hip bone where it should be logical and that was a mistake
here is the answer with pictures (and abtout spring effect too) http://www5a.biglobe.ne.jp/~hirospot/iClone/MMD3DX5.4/index.htm
Hi, Here is my another report for using MMD Elsa & frozen motion in iClone. You can download FBX sample data for her facial morphs at the link in Chapter 3-5.
Have fun, Hiro
By sakurarinani - 8 Years Ago
Is this still up to date? I have ton of problem about this matter such as no texture,color became when import 3dxchange to iclone and doing facial expression 😅 I am not good 3D stuff but manage to import character via blender with mmd tool and cat plugin....
;screenshot how far i can do with google test and error include hirotspot report( cant go far because part i dont understand) color a bit gray
 no texture
 Ps: Maybe to must ask but can any master about this matter help me convert my pmd model with right color ,have compatible facial expression iclone and working physic of hair and clothes.... will sent out file for this... I am really grateful if someone can help...
UPDATE: 1: I'm manage to import successfully prop object via pmd/pmx import to blender export as .dae then import to SketchUP then export as .skp lastly import to 3dxchange and prop is right color in iclone and 3dxchange..
 but have some texture that not right if can see the picture about here Blender pic
 You can see the tree is not gray in blender but in sketchup and 3dxchange it come out weirdly.
EDIT 2: I mean blender to dae then convert it into fbx via FBX CONVERT (AUTOCAD APP) then import to 3dxchange. Step that success*
All this test and error if i do this kind of stuff i don't know what disadvantage about this and don't know if it compatible with iclone animation i'm still have problem about facial expression and physic for cloth and hair...
is there any guide step by step....? or someone can help me about this stuff :D
By wires - 8 Years Ago
Why jump through all those hoops when you can export as OBJ or FBX from Blender and then run the files directly through 3DXchange to iClone?
wires (6/1/2018) Why jump through all those hoops when you can export as OBJ or FBX from Blender and then run the files directly through 3DXchange to iClone? Because it give bright color or not color and wrong texture on 3dxchange when i am try normal conversion blender to fbx and to obj😫 so i go all the hoop it work... point me if there any right way to fix texture problem.
Edit: test again.. it dont work anymore i dont how it happen but it give same result as normal conversion.... Edit: only some skp model work some dont work
By hirospot - 8 Years Ago
@sakurarinani Re: PMD or PMX conversion for iClone Use for FBX pipeline from Blender to iClone. The report was based on Windows 7 Japanese Version, so please let me know if you have any discrepancies.
Thank you, Hiro
Re: PMD or PMX conversion for iClone Use Sample movie to demonstrate the FBX conversion result for the following three characters and Stage. (Here) ・AmamiyaHibiya.pmx ・Farun.pmd ・Anime Girl.max ・White Garden.pmd
Thank you, Hiro
Re: MMD PMX model conversion for iClone Use Here is my new report and video for PMX Character FBX conversion for iClone use.
 Report:【MMD】 Lana (The League of Zelda) ECOH dance on iClone http://hirospot.web.fc2.com/iC5J_MMD_Lana_ECHO/index.htm Demo Video:【MMD】 Lana ECHO on iClone 5 https://youtu.be/S8gZvryVQEE Thank you, Hiro
By Purpl3Pix - 6 Years Ago
I hope this thread is still ongoing, since I just found out about it through another member! So I've found a way to import my Splatoon 2 models from MMD into iclone7. or into 3dxchange! I'm really just having trouble with mapping the bones correctly. i can't find a tutorial on how to properly map the bones on a model that has so many. if anyone is able to map them and create a profile for the model that would be a HUGE help since all of the models work the same. (A characterization profile) i believe it's called! Will be awaiting rep[lies :) i have also attached a rar file with her 3d OBJ file thats the converted version of the pmx in my other forum post since i don't have any space here Link to model
So i was tinkering with it some more and when i finally mapped the bones this happens >_>
 seriously i'm at the end of my ropes, can anyone please help me with this? i will pay anyone that can figure this out! I'm really that desperate to get these models working in iclone7!
By 4u2ges - 6 Years Ago
Purpl3Pix (5/10/2020)
So i was tinkering with it some more and when i finally mapped the bones this happens >_>  seriously i'm at the end of my ropes, can anyone please help me with this? i will pay anyone that can figure this out! I'm really that desperate to get these models working in iclone7!
Go to third icon from left (bulleted lines) below Save button and fix Hip Offset
Now send me $10... Just kidding :D
I'm sorry But im kida lost lol could you explain that again? [EDIT]; NVM i got what you were saying lol took a minute to figure it out. thanks so much.
