Mocap Refinement Tutorials
https://forum.reallusion.com/Topic125007.aspx
Print Topic | Close Window
By KaiD - 14 Years Ago
Hi all,
Here are a couple of tutorials that will teach you some procedures for turning your raw motion capture data into a refined motion using various editing techniques.  Even if you don't use the mocap sensor, you should check these out to get some tips on how to customize any of your other motions as well! :)
Beginner Level - Human IK & Direct Puppet
Intermediate Level - Looping & Motion Layer Editing
Advanced Level - Aligning/Removing Motions, Time Warp & Insert Frame
By Smimmer - 12 Years Ago
KaiD (6/5/2012)
Hi all
Thanks, this helped a lot.
I've only had the opportunity to watch the first video so far.
Would you happen to know if there is a way to use two Kinects?
Hopefully you or someone that can answer this is still around. I see that this is a very old thread : /
By planetstardragon - 12 Years Ago
Hi Smimmer,
Welcome to the forum!! :D
In the current version we are limited to 1 kinect, you never know what the future holds though!
Cheers!
