Elephant or Monkey-faced human
https://forum.reallusion.com/Topic117953.aspx
Print Topic | Close Window
By sharad.inc - 12 Years Ago
I would like to model an iClone STANDARD character (G5) which has the face of either a monkey or an elephant (reference images attached). I would like to have some expert opinion on the "best-way" forward
Elephant-face
1) Use the G5 character template in 3DSMax and extend the nose mesh into an elephant trunk
concerns: feasiblity of doing so without having to add extra vertices? can the elephant-trunk be soft-body enabled? can the nose be still animated separately using Crazy Talk?
2) Attach a soft-body prop to the face
concerns: feasibility? animation inside iClone? or import some default animations alongwith the prop
Monkey-face
1) as above - I guess this should be feasible. But how do we deal with the tail? As in (2) above?
Any help in this regard would be sincerely appreciated.
Regards,
By Apparition - 12 Years Ago
Why not try both?
Success comes from experimenting.
A tail with springs or with animation controls is easy to do!
Use exactly the same method described in the Springs tutorial.
For the elephant I would make the ears and nose as Props with skin controllers. Then at iClone make them into accessories. (That is what I would do)
Mike
By francois.meres - 12 Years Ago
Monkey face is not difficult look for exemple chuck :
a little head transformation ....
By Sen - 12 Years Ago
Hi ,
Monkey_faces :
