Saving error - File will not open - File went to 0 bytes
https://forum.reallusion.com/Topic110344.aspx
Print Topic | Close Window
By renjain - 14 Years Ago
I received the attached error when I went to save (see attached also):
"Error saving project file. Please check your access right to file and the disk space, or change the temporary folder path in preference setting."
There are three different possible errors suggested above (admin rights, disk space, temp path)
-I was logged in as admin and I was not saving to a protected folder
-I have enough disk space
-It wouldn't allow me to remap to another temp folder
I was forced to quit out of the program as my changes could not be saved without that error popping up. I went back to open the file and it is at 0K. Please tell me my file is not dead. Help!
By planetstardragon - 14 Years Ago
that sounds like a system error, I'd try running a defrag on your system. This usually tries to fix any linked / cross linked files or at least tries to remove any system errors to prevent it from happening again. I'd also try to reach tech support to double check that the way cta is installed in your system isn't causing it. i've never experienced problems like that from ic5 or cta, but i have experienced the system doing that with any program thats up at the time. I'd also run a scan for viruses as well, a virus or a malfunctioning TSR program will cause errors like this as well.....(TSR, the programs you have running in the background )
if you are an intermediate level user, you could try this as well....disclaimer.. use with caution, and at your own risk....this works for my system, but not all systems are alike...
2 softwares I use to maintain my computer are ccleaner ...it cleans out garbage files and potential registry issues http://www.piriform.com/ccleaner
and malwarebytes to scan for malware / viruses etc.. http://www.malwarebytes.org/
both programs have free versions.
Good luck!
Unfortunately, that did not work. Does CTA have some sort of autosave and/or autorecovery built in?
Also, is there phone support available?
By Peter (RL) - 14 Years Ago
Hi Renjain
I see both you and planetstardragon are referring to CTA (CrazyTalk Animator) but I'm assuming by the error message you mean CrazyTalk 6 (CT6).
Unfortunately CrazyTalk 6 doesn not have autosave so this won't help in this case.
I'm not sure if the problem is happening to just one single project or happening to all projects but certainly I would advise you contact Technical Support using the link below. They will be able to help you try and resolve this issue.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
By williamafranks - 13 Years Ago
Did you find a solution to the problem?
