By Anonymous - 19 Years Ago
I dawnload the program and i install the program on my computer . the version was trail after 15 day the trail finished so i unistall the program . after one month i install the program but the program did not work because the 15 day finished . not this the problem . after that i start search on internet to find a crack or a serial number or a patch because i cant buy the program because we at the u.a.e the 59.95 $ it is so mush because The difference in the currency exchange i find a patcher his name is Reallusion FaceFilter 2.0.1206.1(S) - Bidjan
i open the patch and followed the instructions and i think that the program will work normal but when i open the program Open for a few seconds and then closes like flash what the problem and how i can solve it. thank you
Hi Sky2007 I know the program may be expensive for you but by downloading cracks you first of all are obtaining software illegally and second, you are risking infecting your computer with viruses. if i were you i would remove the program, check your computer for viruses and wait till you have the money and buy it.
bluesky
You can solve it very simply by purchasing the product like everyone else. What you are attempting to do is illegal and you can find yourself in serious trouble by so doing so.
If Facefilter is too expensive for you then you will have to do without it. It's as simple as that. If you can't afford a car will you consider stealing one? The principle is exactly the same.
I think you should also take notice that by posting on this forum your IP address is known and you could be traced and possibly prosecuted for software theft if you continue to try and obtain this software illegally.
Peter Edwards (movicomuk) Moderator
http://iclone-daily.blogspot.com/
