Advanced particle settings
https://forum.reallusion.com/Topic107775.aspx
Print Topic | Close Window
By brand468 - 14 Years Ago
Hi, my wish is more advanced 3d particles and settings in iClone.
I need more realistic particle effects in my iClone projects so i now using "HitFilm ultimate" http://hitfilm.com/ultimate to add effects on my rendered iClone videos
It would be great if i could do better effects inside iClone. :)
By Peter (RL) - 14 Years Ago
Thanks for the feedback. This has been passed to the iClone team. :)
By JasonJ68 - 14 Years Ago
It would be great to have "attractors" and "repellers" for the particles.
By Sifr - 14 Years Ago
It would be fantastic if animated texures could be attached to the particle sprite sheets in png. format so I can fully utilize this awsome particle feature.
Currently I use this particle texture progam http://www.rigzsoft.co.uk/ in my pipeline you guys might want to consider aquirering this small company..... hey, you gotta exspand sometime.;):D:w00t::cool:
Wow, TimelineFX seems to be a great 2D particle effect  software!
I have also pIllusion but I now use HitFilm that generate particles I 3D space when i need more realistic effects on my iClone renderings.
iClone have a great 3D particle generator but It would be nice if the particle effects inside iClone get more settings :)
Some whishes:
-        Particle bounce when hitting a wall or a hidden layer
-        Particle blocking so it stops at a wall
-        Light and shadow influence on particles
-        Scale all settings inside a particle on same time
-        Reduce speed on particle to make realistic smoke
-        Group several particle effects
-        Pre start so particle is fully grown at frame one when rendering
