Iclone5 animation playing slow in software
https://forum.reallusion.com/Topic100000.aspx
Print Topic | Close Window
By suresh.jallipalli1 - 15 Years Ago
hi,
when i am animating in my iclone5 pro, the animation is playing very slowly even though i am making fast animation.The numbers of frames at which i am animating the characters is 25fps and also i am unable to listen to the dialogue in iclone software,where it is audible normally.
but iclone4 is working good.so i think might be software problem.please show me a solution
By kvpictures1 - 15 Years Ago
Check at the bottom to make sure you don`t have "By frame" enabled, if so click it to switch to realtime. By frame is intended for more accurate physics simulation.
thank you
