StanDeMand
StanDeMand
Posted 13 Years Ago
Visits: 224
I use IClone 4 standard and CrazyTalk Animator pro and I tried to use a green screen background (Pop Video Editor) with the Crazy talk Animator characters. If there is a way, can someone tell me how to do it correctly with or without chroma key?
Posted 13 Years Ago
Posts: 22.6K,
Visits: 35.6K
All you need to do is export your character from CrazyTalk Animator in .popVideo format. As long as you don't add any background into your CTA scene, your character will be exported with a transparent background. Then you can just drag the exported popVideo into your iClone4 scene.
StanDeMand
StanDeMand
Posted 13 Years Ago
Visits: 224
Thanks mate
StanDeMand
StanDeMand
Posted 13 Years Ago
Visits: 224
The only problem is when I drag my CTA character into IClone 4, the character blends into whatever IClone set that I'm using. It changes the set and has a shadow image of the CTA character.
Posted 13 Years Ago
Posts: 22.6K,
Visits: 35.6K
When you drag your character popVideo into the scene, hold down the right mouse button. This will give you the option to add it as an Image Layer, Billboard, Plane or Background Texture. Unless you specifically want to use it as an image layer you would normally choose either Billboard (always facing front) or as a Plane (fixed view). If you wish to turn off the shadow you can do so on the Modify Panel.
StanDeMand
StanDeMand
Posted 13 Years Ago
Visits: 224
Thank u so much my friend. I appreciate your help.
cynsegura
cynsegura
Visits: 1.1K
Hi there I have crazy talk 2 pro pipeline.. Trying to use them into iclone . Is that possible I read I need them in pop video converter.. But I don't find the way to render the with crazy talk animator 2 pro pipleline.. Any tip??
vidi
Posts: 10.8K,
Visits: 40.2K
CTA2 comes with 32 and 64 bit Version For export pop.video Run the 32-bit version. You will find this version here C:\Program Files (x86)\Reallusion\CrazyTalk Animator 2\ Bin
9 Years Ago by
vidi
thebiz.movies
thebiz.movies
Last Active: 9 minutes ago
Posts: 2.0K,
Visits: 41.0K
I mixed CTA and IClone in a video (Sushi Ronin) but did it in reverse shooting scenes in Iclone and importing those scenes into CTA as a prop (just a big screen that could be resized) Its mostly just the backgrounds but at the end there's a scene where the two mix.
9 Years Ago by
thebiz.movies
mark
Posts: 4.8K,
Visits: 16.4K
