Posted 12 Years Ago
Posts: 15.6K,
Visits: 30.3K
Sen
Posts: 2.8K,
Visits: 28.5K
Hi animagic , I have update my post
CGTRADER
pmaina
pmaina
Posted 12 Years Ago
Visits: 2.2K
nicholis.muller (4/19/2012) Hi all,
I was hoping someone can help .. ever since I updated to the 5.2 patch, every single scene with water the water is turning up either black or grey. No matter what I do I cnat seem to get it fixed. PLEASE help !!!
NickSame here. Anything shiny / reflective not displaying well. Figured it was a bug so am sure its gonna be fixed. I know the interim fix is stop gap and probably not tested so am waiting for a robust solution hopefully ASAP please! ==================== WARNING 5.2 will crash if you make certain adjusts to ambient light. Save your work b4 attempting. Also, last night 5.2 froze on me completely for no apparent reason. I had to redo quite a bit of work. ===================
Posted 12 Years Ago
Posts: 22.6K,
Visits: 35.6K
Sen (4/22/2012) Hello ,
I can't submit a ticket 'no work since 3 days ), so I post here :
edit character in 3dx5 don't work , seem to load , but nothing in 3dx5 . Drag and drop ok and open directly by 3dx5 ok. Hi Sen Apologies for the Support Form problems. There was an error over the weekend but this has now been resolved. For the issue opening characters in 3DXchange5 directly from iClone5, we are not able to reproduce the problem so far. Can you let us know the following: Does this issue occur with all characters? Does the issue only occur if 3DXchange5 is already? Do you still have 3DXchange4 or any other version of 3DXchange installed? Thanks for your assistance. We will look into this issue.
Shaky
Shaky
Posted 12 Years Ago
Visits: 9.2K
I updated to 5.2, but did not reload to 64 bit. There are projects that will not open now, that did open before. I also have a character that will no longer open. The programs thinks I'm trying to open a prop.
Can anyone help?
Posted 12 Years Ago
Posts: 5.7K,
Visits: 26.4K
@Peter, Thanks for the answer on the .vns faces, only problem at the moment is that iClone 5.2(32 Bit) freezes up and crashes when trying to attach a .vns face to a G5 Body - not a real problem as I still have enough G3 stuff to last for a long while. @Sen, I did what you showed in your screen grab video and couldn't reproduce the problem. I have iClone 4.3 and 5.2(32 Bit) and also 3DXchange 4 and 5 installed on a 4 GB Win XP (32 Bit) system.
Sen
Posts: 2.8K,
Visits: 28.5K
A very good person had submit a ticket for me . Thanks . ic5.2 run as admin same issue (32 or 64 bits ) . 3dx5 not open or open same issue . All character G1 to G5 , non-human and non-standard same issue . I don't have 3dx4 , but iclone 4.31 yes . I will try on my laptop in few hours , and install 3dx5 for test . On my laptop all work fine .Only ic5.2 32 bits install .
CGTRADER
12 Years Ago by
Sen
Postfrosch
Postfrosch
Posted 12 Years Ago
Posts: 6.9K,
Visits: 18.4K
Hello friends, Avatars put my self-created landscapes on a strange behavior on the day. If I de-Mixmove Begehl "Go" viewed the avatars go immediately to their knees. I must first set up with the arrow. If I Mixmove after the command to another command such as from the movement control - they fly out of the scenery. I also konntre öffteren of the Gizmo to ausriochten of avatars no longer use. EEA had completely disappeared, reappearing only when a new Projekt again. (No, I do not have it turned off.) In the RL-landscapes I've not yet found. Greets from Germany Werner (Postfrosch)
Posted 12 Years Ago
Posts: 22.6K,
Visits: 35.6K
animagic (4/7/2012)
There is an issue with certain packs that rely on animating the UV offset to simulate movement. Examples are the Stage Magician pack and the walkway in the Skywalk prop (Movie Sets Vol. 1). When you select an available option from the Perform menu in those cases, nothing happens. Other performances still work. I believe this has to do with the fact that in IC5 the Material channel has been split into two components: Material and UV. Somehow the UV information does not get into the UV component when inititiating a Perform option. Hi Animagic Just to let you know the issues you mention will be looked at by the content team. Unfortunately with every new release of iClone it becomes increasingly difficult to ensure every content pack will work perfectly, especially those originally designed for iClone 2 or 3. Hopefully we can get the packs you mentioned updated to be fully compatible soon. Once I know more I will update again.
Posted 12 Years Ago
Posts: 22.6K,
Visits: 35.6K
pmaina (4/23/2012)
Same here. Anything shiny / reflective not displaying well. Figured it was a bug so am sure its gonna be fixed. I know the interim fix is stop gap and probably not tested so am waiting for a robust solution hopefully ASAP please! ==================== WARNING 5.2 will crash if you make certain adjusts to ambient light. Save your work b4 attempting. Also, last night 5.2 froze on me completely for no apparent reason. I had to redo quite a bit of work. =================== Thank you for the feedback. With all new updates to iClone it is also wise to check for any updates to your graphics drivers. Updating your drivers may resolve these issues and is certainly worth a try.
