iClone5 Issues Thread
Posted By Peter (RL) 13 Years Ago
Magique
Magique
Posted 12 Years Ago
Posts: 315, Visits: 1.4K
Thanks, Peter. That's the kind of solution I was hoping for. I tried in Backstage and it didn't work that way. I didn't realize I could do it from the web page.
planetstardragon
planetstardragon
Posted 12 Years Ago
Posts: 11.5K, Visits: 45.9K
Official Bug! - i added grass to a terrain, I roll the animation, and the grass suddenly disappears at the exact spot every time. I went to the timeline to see if there was any animation that turned it off, and realized you can't animate anything about grass in the timeline!
things i did that might have affected it,
-adding grass in middle of scene, not frame 1
-made a part of the model i had added to terrain invisible ( but it was invisible from frame 1 so I doubt this caused it )
-turned off the bounding mesh so the grass would follow the contour of the custom terrain.
12 Years Ago by planetstardragon
twilit.tera
twilit.tera
Posted 12 Years Ago
Last Active: 12 Years Ago
Posts: 257, Visits: 747
I've got another "things disappearing" problem - I loaded a texture that I had edited into the diffuse. It looks fine until I hit F10 to look at the preview. Opacity set to 100% and no opacity map loaded. Screenshot attached.
Edit: I got to thinking about it. I pulled Chuck in: default character. F10 made another hollowman. So I figured it must be a setting somewhere. I tested the different shading options (you know the work in progress display settings) and found that it had that effect on everything but full pixel shading. So. I can mess with the puppets all I want with the quick shader/wireframe options, but when I want to test the final image, we need to change the setting before hitting preview.
Tera
Like BnTWerks Media on FB!
invisible face.JPG (65 views, 128.00 KB)
12 Years Ago by twilit.tera
planetstardragon
planetstardragon
Posted 12 Years Ago
5.12 update brought up some bad bugs in motion layer ....i move head, arm spaz's out , i move wrist elbow flies into chest. extreme jolts. pretty hard if not impossible to keyframe now. when i move the toe, the head and arm move lol and with the sdk confusion, this update....um..fail - good to know you're human, but ya killed my flow !!
wishful feature - Update Rollback! Tongue
namunger
namunger
Posted 12 Years Ago
Posts: 233, Visits: 1.1K
planetstardragon (2/13/2012)
Wow, same problem here! Weird thing is, I was using it earlier today (with update applied) and it was fine. Close and restart and hour later, motions are totally freaking out! I was hoping to get a video done before tomorrow, too.
planetstardragon
planetstardragon
Posted 12 Years Ago
hopefully their swat team will have this fixed quick Smile - I just double checked it with a reboot, same thing almost instantly, i had 2 normal adjustments, 3rd adjustment was a head movement that sent the arm flying into the chest. something definitely broken in the edit motion layer with new update.
namunger
namunger
Posted 12 Years Ago
It seems to be intermittent - now that I've given up and need to go to bed, it seems to be working again!
namunger
namunger
Posted 12 Years Ago
Any updates on this bug? 3 out of 4 times I start up the program, character animation is completely out-of-whack.
planetstardragon
planetstardragon
Posted 12 Years Ago
it's been a hit or miss for me, sometimes when it does make those erratic moves, they snap back into place when I let go of the gizmo, other times re-saving the file to be a few frames longer and reloading it works around it. I'm sure it's one of those things thats a delicate balance since they have all the auto correction - restraint features in place. It would be nice to have the update rollback feature though, I can certainly appreciate the amount of detail that must go into balancing this ambitious system, but it would be nice to be able to roll back to a version that we are at least use to until bugs such as these are fixed. less pressure on the programming team and the users, should updates have new bugs.
Posted 12 Years Ago
Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)
Last Active: 30 minutes ago
Posts: 22.7K, Visits: 35.7K
Thanks for the notification PSD and Namunger.
I will try to get some feedback from the iClone team on this issue ASAP and report back.
