NeonLaurence
NeonLaurence
Posted 13 Years Ago
Last Active: 13 Years Ago
Visits: 3
Hi,
I'm using CrazyTalk on a Mac using VMware Fusion (effectively running windows on a mac). Two problems: 1. it is incredibly slow 2. When I bring in an image it looks fine, for about 3 seconds. Then it becomes blurred and the output ends up equally blurred. I'm new at this so I'm sure I'm doing something wrong. Any help appreciated.
Laurence
Posted 13 Years Ago
Last Active: 10 hours ago
Hi Laurence I have no personal experience of using CrazyTalk 6 on a Mac but it does sound like a graphics card issue to me. Normally the PC advice would be to update the graphics drivers but this is not so simple on your setup. I would advise contacting Technical Support using the link below. They will be able to advise you further on this issue. https://www.reallusion.com/CustomerSupport/User/QForm.aspx
NeonLaurence
NeonLaurence
Posted 13 Years Ago
Visits: 3
Thanks Peter, will do that.
ahmeepro
ahmeepro
Posted 13 Years Ago
Visits: 273
I'm having the same issue with my HP Pavilion dv7 laptop
Posted 13 Years Ago
ahmeepro (10/12/2011) I'm having the same issue with my HP Pavilion dv7 laptopThe original question relates to Mac users rather than PC's. This type of problem on PC's is normally related to your graphics card drivers or settings. Is the problem on export to video only or when using CrazyTalk itself? First thing you should do is ensure your graphics drivers are up to date and you have also updated CrazyTalk 6 to the latest version which is 6.21. Doing these two things will normally resolve most graphical issues.
aclem2004
aclem2004
Posted 12 Years Ago
Last Active: 12 Years Ago
Visits: 7
I have Crazy Talk 6.21 and used it quite a bit in Fall of 2010, with good results. I tried using it recently and it wouldn't work so I reinstalled it. Since re-installation, it's useless.
System Info: Compaq Presario CQ60 AMD Athlon Dual-Core QL62 2.00 GHz 3.00 GB (2.75 GB usable) 32-bit Operating System Windows 7 Home Premium N
The problem:
1. Every action is incredibly slow, maybe 30 seconds to open a new project, select a picture for a model, and any further action takes similar time. A 4 second render took 4 or 5 minutes and looked horrible, though the mouth worked (at least).
2. The imported picture for the model starts out fine but quickly blurs badly.
3. I look at Task Manager and it is taking up 50% of the CPU, more or less, even when doing nothing.
4. I have tried the graphics fixes and nothing changes.
Something is very very wrong here. The program is now totally unusable. It worked before, but after reinstallation, it's useless.
Posted 12 Years Ago
Hi aclem If you have checked you have the latest graphics drivers installed and all Windows Updates then please contact Technical Support using the link below. They will be able to advise you further. http://www.reallusion.com/CustomerSupport/User/QForm.aspx
