Stock Graphics - What Size is Best?
Posted By Mauidelite 13 Years Ago
Mauidelite
Mauidelite
Posted 13 Years Ago
Last Active: 11 Years Ago
Posts: 69, Visits: 214
When purchasing stock graphics for use in CT6 projects, is there a size that produces really good video?
687x800?  1605x1868?  2072x2412?
Should I be looking for vector only graphics?
Any suggestions of where to get good graphics would be appreciated!
Lauri
Posted 13 Years Ago
Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)
Posts: 22.7K, Visits: 35.7K
Hi Lauri
CrazyTalk 6 Pro supports image files up to 8 megapixels so all the sizes you list are supported.
Overall the largest size will give the best results but you can still get very good results with smaller sizes. And you don't need to use Vector images. Raster images work just as well in CT6.
Mauidelite
Mauidelite
Posted 13 Years Ago
If you use a smaller size - like the 687x800 - will that affect the output video?  Will it be less sharp?
Posted 13 Years Ago
It really depends on the amount of compression you use in your final render. Even large images will look bad you use heavy compression in your outputted video.
If you use a HD setting for output then your results should be quite good with only a little degradation in quality by using the smaller image size. A larger image size will allow output to look that little bit sharper and clearer.
