CrazyTalk Animator v1.2 Released
Posted By Peter (RL) 13 Years Ago
Posted 13 Years Ago
Last Active: 24 minutes ago
Posts: 22.7K, Visits: 35.7K
CrazyTalk Animator Version History
v1.2 (1.2.2010.1) released 18th August-11
•Added: SWF output. >> More Info
•Added: Increased audio limitation to 8 character voices (original was 4).
•Fixed: Feet sliding issue in the Actor Key Editor.
•Fixed: Motion Keys disappeared after ungrouping motion clips in the Timeline.
•Fixed: Prop command issue after props were attached in the Composer Mode.
•Fixed: MP4 quality issue during export.
You can upgrade to this latest version by running LiveUpdate from your Start Menu/Reallusion or by logging into your Account and choosing Bonus & Upgrade.
More information on this upgrade is available HERE.
v1.11 (1.11.1614.1) released 18th April-11
•Added: Support for Virtual Machine on Mac.
•Added: Supersampling in export function. (elimination of jagged/pixelated edges)
•Fixed: Crash issue when applying Facial Components from the Face Library.
•Fixed: Motions disappear after ungrouping motions in the timeline.
•Fixed: Thumbnail display replacement issue in the Sprite Editor.
v1.1 (1.1.1516.2) released 23th March-11
•Added: Layer editing in Scene Manager.
•Added: Save motion option with custom layer key.
•Added: Multiple props selection with merge function.
•Added: Flexibility on project timeline editing. Able to delete or insert frames into a Project.
•Added: Able to scale the window size for Face and Body Fitting.
•Added: New connection points to a character for auto snapping when exchanging content.
•Added: For the convenience of the users, we changed the policy to allow for up to TWO simultaneous installations on separate computers. The policy remains a “single-user license”. Permanent use on more than one computer will require an additional license.
•Enhanced: Action Menu Editor with full editing features including; add, remove, rename and sort.
•Enhanced: Better Performance on Switching Modules such as; Key Editor, Face/Motion Puppet, Character Composer and Load Project.
•Enhanced: SWF file compatibility.
•Enhanced: Motion Layer for Sprite Switching - the Sprite Switch timeline interface is enhanced by using effect ranges to replace keys; now the Sprite Switch track will have the highest priority as it will overwrite sprite animation in other tracks.
•Enhanced: SWF file compatibility with vector image rendering resolution so it can result in smooth vector curve after rendering export.
•Changed: Content purchase entrance now moved from Backstage application to the Reallusion City Marketplace.
•Fixed: Prop layer order issue.
•Fixed: Sound issue of videos exported with popvideo prop inside.
