I've never used iPi with Kinect, but Brekel. Brekel has no smoothing filters, but it's using the same open source drivers as RL will use.
So:
It's really cheap
Driver installation is no problem
on fast PC, capturing works great
Configuration is done in seconds (you should tell how deep the Kinect will look)
Calibration needs seconds also
what is not so good:
The drivers have no support for 2 people at once (rughly they have, but Brekel never used them, with RL it might be the same)
The Kinect can't see through anyone, so what you are doing on your back is something the software has to guess.
These are the most disatvantages I think.
The last thing isn't a great problem I think, as you could capture from the same angle as you will use in iClone
and the first big problem might be solveable with a better interaction RL will introduce in iClone. Eg two people kissing each other.
So, afterall, the puppy from the first post might be great fun to use, and there are some poses you will not be able to get with Kinect. Eg laying down on the floor, or making a breakdance (never tried, but I think so ;-) ). But appart from these examples, Kinect might really be enough.
Oh, I've forgotten one thing:
No hand movements. But this could change.
________________________________________________________________________________________________________________________________________
Danke für Flex - Haare und Kleidung, die nicht durch den Avatar gehen !
13 Years Ago by
yaRincewind
