renjain
renjain
Posted 13 Years Ago
Visits: 120
I want to record my audio within CT with my usb mic, but my input device (Snowball mic with usb connection) does not show up in the list. I've shut down, rebooted, unplugged, plugged back in, restarted CT etc. It still doesn't show up, but it shows up fine in other programs. Please advise if there is any way to add a device within CT.
Posted 13 Years Ago
CrazyTalk will normally use the audio recording device that is set as default. If you go into your system Control Panel - Hardware And Sound - Manage Audio Devices, you should be able to see the recording device that is set as Default. If it isn't the set to the microphone you wish to use you can change it in Control Panel. This should solve any sound problems you are having.
