jturpinrn11
jturpinrn11
Posted 13 Years Ago
Last Active: 6 Years Ago
Visits: 41
Hi! Somewhat new to Iclone, but I noticed that some material content is not showing up. I can see the file when I check the Program Files, just not in Iclone itself. The content packs I am having problems with in the Toon Kids series and MR Pose and friends. What am I missing? Thanks
Mel H
Mel H
Posted 13 Years Ago
Visits: 8.1K
Hi iTurpinrn 11 In windows XP: Documents and settings/all users/shared documents/Reallusion/Template/iclone 4Templet/icloneTemplate/Material Lib.
Carmello Holden
13 Years Ago by
Mel Holden
jturpinrn11
jturpinrn11
Posted 13 Years Ago
Visits: 41
So there's no way this shows up in IClone? I have to import it each time?
gizmo
gizmo
Posted 13 Years Ago
Visits: 1.6K
Hi. Select your character. Select 'Upper' (top preview screen). Go to 'Modify Panel' (on the right). Under 'Material & Texture settings' make sure the diffuse box is selected . . . it usually is when starting . . . select the 'Load Material' button. That should take you to the Material Lib Folder. If not you will need to navigate as Mel has described above. (iClone then remembers this location unless you change it). Look for your texture , click and OK or double click. Repeat for 'Lower Textures' etc. Once you have loaded what you need you can save the whole character. Select 'Character, Custom', select a folder or make a new one and click the '+' (Add) button. Or you can save just the Upper or Lower by the same method. Thereafter you can just load directly from iClone. Cheers.
gizmo
Alley
Alley
Posted 13 Years Ago
Posts: 3.7K,
Visits: 12.8K
Just another thing to point out is that the toons and mr. pose are "Skin" materials, not Upper and Lower. So you must select the "Skin Tab" at the top, then the various skins in the drop down at the side (upper, lower, shoes, hands & face) and load each one. These material files for "Skin" should be in the same location as per Mel above. After you have loaded the materials on your character, "Save" the character and it will always be available in Iclone.
Alley
jturpinrn11
jturpinrn11
Posted 13 Years Ago
Visits: 41
Thanks a lot! I didnt realize they were "skins" I will try this when I get home. Hope it solves my problem!
gizmo
gizmo
Posted 13 Years Ago
Visits: 1.6K
jturpinrn11 (6/1/2011) Thanks a lot! I didnt realize they were "skins" I will try this when I get home. Hope it solves my problem!No, but I've been playing with iClone long enough that I should have remembered. My apologies for sending you slightly up the wrong path. Cheers Alley.
gizmo
jturpinrn11
jturpinrn11
Posted 13 Years Ago
Visits: 41
Thanks Again! IT WORKS!!!! Cant wait to play more with it!
