A problem caused the program to stop working when importing sound
Posted By Giddy_up 13 Years Ago
Giddy_up
Giddy_up
Posted 13 Years Ago
Senior Member (434 reputation)Senior Member (434 reputation)Senior Member (434 reputation)Senior Member (434 reputation)Senior Member (434 reputation)Senior Member (434 reputation)Senior Member (434 reputation)Senior Member (434 reputation)Senior Member (434 reputation)
Last Active: 12 Years Ago
Posts: 3, Visits: 29
Hello!
Each time I try to import mp3 as background music, sound fx1, or sound fx 2 I get the error:
A problem caused the program to stop working.....read your post regarding the file PROGRAM on the C drive....so that is not an issue.
Also it happens at any stage when i import....first thing....in the middle of the scene...etc.
Thanks for your help!!
Jill
Posted 13 Years Ago
Posts: 22.7K, Visits: 35.7K
Hi Jill
A few things to try.
Check with your computer manufacturer for any updated sound drivers. You can also run Windows Update from the Start Menu and check if there are any new drivers found. This may help.
Make sure you have CrazyTalk Animator updated to the latest build which is version v1.1.
Try using some different MP3 file or a PCM WAV file instead just to eliminate a faulty file.
If after trying the above you still have problems then please contact Technical Support using the link below. They will be able to look at your system in greater detail and advise on how you can best resolve this issue.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
