peteradam6
peteradam6
Posted 13 Years Ago
Visits: 1.9K
http://www.reallusion.com/press/freebies.aspx
Same problem with the Feb 2011 destructables freebie, as I had with the boots. IClone 4.12 pro is 'too advanced' for the old installer. I get a warning message to that effect, and the installer quits.
Yes, I have the very latest version of iClone 4 Pro.
| iClone 5 Pro | 3DXchange 4 Pro | popVideo Converter 2 | CrazyTalk 6 Pro | CrazyTalk Animator Pro |
Sen
Posts: 2.8K,
Visits: 28.5K
Hi , strange , no problem for me . IC 4.31 pro , seven x64
CGTRADER
13 Years Ago by
Sen
namunger
namunger
Posted 13 Years Ago
Visits: 1.1K
Worked for me, but I get a windows popup box that says it didn't install correctly. I close the box and check IC, and everything's fine, so I'm not sure what it's talking about (all the freebies do the same thing for me).
Posted 13 Years Ago
Last Active: 12 hours ago
Posts: 22.6K,
Visits: 35.6K
Just tried the freebie detructible pack and it installed fine into iClone 4.31 for me too. Have you had trouble installing any purchased content packs or is it just limited to the freebies?
duchess110
duchess110
Posted 13 Years Ago
Posts: 2.0K,
Visits: 15.5K
namunger (3/6/2011) Worked for me, but I get a windows popup box that says it didn't install correctly. I close the box and check IC, and everything's fine.Yes same here noticed it is only since Windows 7 that I get the pop up saying not installed correctly.
Duchess Designs Store
Posted 13 Years Ago
Posts: 22.6K,
Visits: 35.6K
duchess110 (3/7/2011)
namunger (3/6/2011) Worked for me, but I get a windows popup box that says it didn't install correctly. I close the box and check IC, and everything's fine.Yes same here noticed it is only since Windows 7 that I get the pop up saying not installed correctly. You can safely ignore this warning message and just select that it installed correctly. It is just a warning because of the version of the installer used. It happens with a lot of content installers including those from Daz etc. Hopefully when the installer is updated this should stop happening.
peteradam6
peteradam6
Posted 13 Years Ago
Visits: 1.9K
I currently have the latest v4.31 Patch (117 MB, 2011/01/20) installed. The installer for the freebie destructibles is from 2008 (that's what it says on the splash image as it starts up). This is the exact fail message it gives me: Some version(s) of iClone cannot install this iClone Bonus Props Pack -
Exploding Elements:
iClone v4.12 PRO:
The version of iClone on your computer does not meet the requirement to install this iClone Bonus Props Pack - Exploding Elements. Please update your iClone to the latest version before you install this iClone Bonus Props Pack - Exploding Elements again. The iClone Bonus Props Pack- Exploding Elements installation will be terminated.It really would be a lot easier if the freebies could be also available as props in zip files.
13 Years Ago by
peteradam6
Posted 13 Years Ago
Posts: 22.6K,
Visits: 35.6K
peteradam6 (3/7/2011) I currently have the latest v4.31 Patch (117 MB, 2011/01/20) installed.
Exploding Elements:
iClone v4.12 PRO:
It really would be a lot easier if the freebies could be also available as props in zip files.The date of the installer should have no impact on the ability to install the content packs. Looking at the message you have received it may be that although you have iClone 4.31 installed, your system registry has not been updated and an earlier version is registered which is causing the problem. Uninstalling iClone and reinstalling the latest full installer from your Account may well solve the problem and prevent further errors like those you have received so far. Please feel free to contact Technical Support regarding this issue who will be able to supply more information and ways to resolve this. http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Sen
Posts: 2.8K,
Visits: 28.5K
Strange , strange system requirement for this freebie : System Requirement =============== iClone 4.3 or above is required. and This freebie is related with the content pack: Special Effects Vol.3 Destructible Building Elements. To know more about this pack, go to: http://www.reallusion.com/contentstore/csproduct.aspx?contentid=AIC430DLENU050120110112001&MenuItem=ic_scene&Type=Props I re-install for test and always ok .
CGTRADER
