qdai (1/28/2011)
Will significant computer hardware upgrades (hard drive, processor, graphics card processor gpu) break the install? Or rather, should your software be uninstalled before hardware upgrades to the same computer? If so, what specific upgrades require uninstalling RL's software?It is only major upgrades that will affect your install count. This is normally a fresh install of the operating system or a hard drive format. If you plan of doing anything like that you should uninstall all Reallusion software first while connected to the Internet. This will credit back your install.
This is why I say that RL's 5 install/uninstall policy makes the software license temporary. If in January, I upgrade the processors on two computers that I have RL software on, that may use up 2 install/uninstalls. Then in June of the next year, if I upgrade/transfer to larger hard drives in the same computers, that may use up another 2 install/uninstalls. That leaves just one install/uninstall. After that, what?
If you change your hard drive and remove the old one then obviously you should uninstall any Reallusion software first to prevent losing your install credits. If you change things like processors, graphics cards or memory chips then that will not impact on the software that is installed.
Does upgrading RL's software reset your install/uninstall limits ( to 5 or higher)? For example, if I have 3 install/uninstalls left and RL comes out with version 10 of one of your applications... if I upgrade to version 10 from version 9, is my install/uninstall limit reset to 5. If so, this turns a perpetual license into a subscription license. If not, you're back to the temporary license.
I've been with some software for 7 years or longer. If Poser, for instance, had a 5 install/uninstall limit, I'd have reached it years ago.
Minor updates to the software does not affect your install count. When a major new version of a title is released you have a brand new serial number and license so you start off with a full install count.
It is important to remember that as long as you uninstall your software while connected to the Internet you will be given your install credit back. It is only times when uninstalling is impossible, like after an hard drive failure that you will use up one of the 5 install credits. As hard drive failures are not a regular occurence you would expect to go many years before using up your 5 installs. Even then contacting Reallusion Support will enable you to have your install count reset.
It really isn't the terrible situation you may think it is.
