Merry Paw
Merry Paw
Posted 14 Years Ago
Visits: 193
Doing some research on using Daz in IClone I came across one tutorial that says you need to use the Daz Decinamator to reduce the models before bringing into IClone.
Is this handled when you use Exchange 4 to do the transfer?
Thank you!
planetstardragon
planetstardragon
Posted 14 Years Ago
Posts: 11.5K,
Visits: 45.9K
they don't. You have to do it before the models get to 3DX or IC4 - High Poly Models Stress 3DX and Iclone a lot - makes them crash if it's too high. You want your face count at around 30k - you can go above and beyond that till around 100K or so ...but it makes you want to throw stuff at your monitor and say nasty things to your computer from how much you see the performance suffer.
14 Years Ago by
planetstardragon
Merry Paw
Merry Paw
Posted 14 Years Ago
Visits: 193
Excellent ok I can do that!
Dreamcube017
Dreamcube017
Posted 14 Years Ago
Posts: 2.0K,
Visits: 2.9K
Do you have to use Daz's poly reducer? I have anothe one already. Can't I use that one?
---------------------------------------------------- ***BEST OF THE CORE** :A music reel demonstrating the different types of music I produce for multimedia. Hope everyone enjoys.
Player not working? Use this link.
My other audio work.
Facebook page:
Creation begins at the core.
planetstardragon
planetstardragon
Posted 14 Years Ago
Posts: 11.5K,
Visits: 45.9K
@Dreamcube - Im sure you can, but I'd go through the preliminary steps first to get the bone structure aligned, and converted to a character, then like all the other iclone characters, export it to 3DX then export the head, body, torso etc and reduce the poly's piece by piece. not to mention, this also would give you the option of say, leaving the head with a higher poly count but the rest of the body low - so you can get the best of both worlds. speed and quality.
14 Years Ago by
planetstardragon
Illustrator Cathy
Illustrator Cathy
Posted 14 Years Ago
Last Active: 9 Years Ago
Visits: 1.7K
I've used Z-Brush's decimation plug-in on DAZ models and it worked fine. I think any decimation program will do the trick. Cathy
Just click on the graphic to go there.
Dreamcube017
Dreamcube017
Posted 14 Years Ago
Posts: 2.0K,
Visits: 2.9K
I guess the part I'm missing is how do I get the bones back into the mesh? What type of export do I do from DAZ?
Facebook page:
Illustrator Cathy
Illustrator Cathy
Posted 14 Years Ago
Visits: 1.7K
Those are great questions! Since I've only done the decimation on non-animated props I'm afraid I can't answer them. We need an expert! Anyone out there with experience? Cathy
Teviniii
Teviniii
Posted 14 Years Ago
Last Active: 8 Years Ago
Visits: 3.7K
High Poly counts aren't nearly as stressful on 3d Exchange as huge texture maps (4000 x 4000, etc.) - that's the real problem. There are various ways around this. One is to use the DAZ Texture Atlas. Another is to import your models into 3d Exchange without texture maps. You can apply the textures later in iClone where they can be manually reduced one by one in conjunction with your art program. Of course, they can be reduced in 3D exchange also BUT only if 3d Exchange doesn't crash from the weight of the textures.
Dreamcube017
Dreamcube017
Posted 14 Years Ago
Posts: 2.0K,
Visits: 2.9K
Yeah, I saw the tutorial and they didn't reduce the polies at all. I wonder if that's the main problem with most programs. Hmm... I konw I've tried animating in Carrara and it's just not doable because things get choppy so I can't key things right.
Facebook page:
