i figured out a way to test this...
a new project showed up as 91kb file size 0 faces.
I took the project i was having trouble with, and removed everything to emulate a new project.
the new file size was 8481kb, with 880 faces, bare project with no props, technically should have even been smaller than a new project because I removed the atmosphere ...and the default pic it uses, so thats less. now while Im sure some of that is undo data, is it all undo data or is some of it unnecessary data being saved with the basic file info ?
update - following this test, I started a new project, to perform another test, To add a model, and remove it to see if it left any residual faces, Iclone crashed instantly ...it was a low poly model. thus enforcing my belief of a memory leakage, apparently the troubled file left some residual data that carried over to a new project.
"To define Tao is to defile it" - Lao Tzu
14 Years Ago by
planetstardragon
