CrazyTalk Animator is not fully compatible with all elements of older content packs but can use the models, scripts and motion clips from these CT6 packs. Because of the different file formats used between CT6 and CTA the simplest way will be to drag the required content from your Crazytalk 6 Template folder into the Preview Window of CTA. Once done you can then save each file in the correct new format in CrazyTalk Animator.
So for example first navigate using Windows Explorer to the location below. (X = The drive you installed Crazytalk 6. If you are using a 64 bit operating system use Program Files (x86).)
X:\Program Files\Reallusion\Crazytalk 6\Templates\Crazytalk 6 Template
Then select the Model folder and drag the required model (.ctm) into your open CTA Preview Window. Once loaded you can save it either as Actor - Character or Head if you wish it to be part of full figure body.
For Motion Clips (.clp) do the same and then save them in your custom Animation - Perform library.
For Scripts (.cts) files you can do the same and then save them in custom Animation - Face library.
Further information will be coming soon regarding the compatibility of older content packs for use in CrazyTalk Animator. Hope this helps for now.
