OK, at this point it is incumbent upon me to prove to the millions that I am more--much more--than a mere smart@.
In that spirit, I have performed a motion edit on a fine mocap supplied with iClone 4, the panting sequence in the Male motions folder. I straightened him up and put him into an ordinary upright posture, and the panting movement carried over.
The clip is attached to this message as a ZIP. If the RL server chops off the .ZIP extension, simply rename the file after you download.
To complete the panting, there obviously needs to be facial animation too, but as far as I know, Collect Clip does not allow you to save these from iClone. Fortunately, you can create this yourself, as follows.
In the supplied clip, you will see your avatar pant twice. Find the first place in the clip where he is at an extreme of the motion, and open Face Key to pull down his chin so his mouth opens. Don't go too far or the effect will not look natural.
Advance a few frames and close his mouth.
Advance a few more frames to the second extreme and open his mouth again.
Close his mouth at the end of the clip.
You now have him panting twice. Repeat the cycle as much as desired.
General Picture - animating now to life itself(tm)
Member of Content Wizards
14 Years Ago by
Paumanok West
