I'm following along with a beginner Tutorial Course from David Arandle (great course BTW)... anyway... I'm Linking a Character to a simple icon Prop. Then I'm applying an Entrance elastic motion to the Prop. (to make the character also follow along with the elastic motion).
I notice that when I play the animation... for the first 2 or 3 frames, the Prop icon is invisible... Even though, when I click on the Prop (and I'm in the first frame) the Opacity shows as "100". The Opacity continues to show as "100" even though it's definitely doing a gradual fade within the first 3 frames.
Now normally, I know, you would want to make that Prop invisible. But just for this experiment... I wanted to have the Prop be totally and completely visible (Opacity 100) throughout the entire animation. But it seems like that doesn't work. It's almost like the Entrance motion has an automatic Opacity setting that can't be overridden. Is that true? Is that how these Entrance motions work?
Also... I tried to Link a G3 character to a Prop and then use a " Spongy Moves" elastic motion... but it failed to work at all. The Character just stayed in one spot, while the Prop and Elastic Motion played it's animation. It seemed the Link failed. Are those Elastic Motions somehow "different" and not able to work with a Linked character? Thanks for any insights you can give. I appreciate the help.
Last Year by
RayR10
