Gif Changing Diffuse Texture.
Posted By buddylovesfrenchfries 2 Years Ago
Veteran Member (566 reputation)Veteran Member (566 reputation)Veteran Member (566 reputation)Veteran Member (566 reputation)Veteran Member (566 reputation)Veteran Member (566 reputation)Veteran Member (566 reputation)Veteran Member (566 reputation)Veteran Member (566 reputation)
Posts: 38, Visits: 213
Yeah tysm! i used your way and yeah i think its the only way anyways sadly thank you! :)
I did this and it doesn't change it just stays the same like a picture
Posts: 8.2K, Visits: 62.6K
Double-click the base color channel and load the gif. It will show up as video, and you can drag out loops.
https://forum.reallusion.com/uploads/images/d222a00f-e360-47e4-b403-413e.png
Data Juggler
Data Juggler
Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)
Last Active: 9 Months Ago
Posts: 1.8K, Visits: 5.6K
I don't believe Gif's are supported, maybe someone else can verify that.
What you can do is duplicate your prop, make sure Unique is selected in the modify section
https://forum.reallusion.com/uploads/images/8b8ad500-6706-410e-8020-0e22.png
Then set each prop to a different texture file. Then on the timeline, change the Modify - Display from visible to invisible for the original one, and change the second prop to be visible at the same keyframe.
https://forum.reallusion.com/uploads/images/57707e56-7541-49c9-b5b6-7789.png
It's not as easy as a Gif, but it works.
If you want it to change a lot of times, I wrote a Python Script for IClone 7 that does some similar. I might be able to convert it to IClone 8 if you need it.
Maybe someone else can tell you for sure if Gif's are supported or not.
Creator of the free website:
PixelDatabase.Net
A Free Online Text Based Image Editor
https://forum.reallusion.com/uploads/images/6e6663e2-0ecf-447a-ab3d-d49d.png
Hello! I am running into a issue. I made a GIF of a texture changing colors. But the gif wont play anybody know why?
