Visits: 425
Collision shapes are always annoying to shape and position. Since the CC3+ geometry is a constant, it should be possible for the software to auto shape and place the collision shapes, or, better yet, generate them based on a reduced polygon version of the character. Also, if I'm dreaming, a more reliable soft cloth collision system would be wonderful too.
Last Year by
0Calvin
argus1000
argus1000
Posted Last Year
Last Active: 3 hours ago
Visits: 11.3K
I always had problems manipulation collision shapes. They don’t really work. Many times, I try to adjust them, but without any change in results.
Mana.Lucine
Mana.Lucine
Posted Last Year
Visits: 292
It is very sad that indespite the evolution IC8 is undergoing but Collision Shape system is still the same as in IC4&5 without change. It is buggy and doesn't give any precise results, even when you spend hours adjusting them, they keep poking through.
toystorylab
toystorylab
Posted Last Year
Posts: 4.4K,
Visits: 28.8K
Collision Shapes definitely need an overhaul/upgrade!
Visits: 508
I find the weight maps are a bit of hit and miss method. Being able to select vertices by painting and applying parameters gives more control where weights are applied to various areas of the mesh. VWD cloth and hair plugin for Daz Carra and Poser gives great results This example has wind affect applied
Last Year by
0oseven
Mana.Lucine
Mana.Lucine
Posted Last Year
Visits: 292
0oseven (1/27/2023) I find the weight maps are a bit of hit and miss method. Being able to select vertices by painting and applying parameters gives more control where weights are applied to various areas of the mesh. VWD cloth and hair plugin for Daz Carra and Poser gives great results This example has wind affect applied
I wish one day we can do this in iClone, the actual Physics system in IC is far from being reliable in comparison with other software and not stable at all.
