Last Active: 7 minutes ago
v8.01 released on June 1st, 2022 Added functions and bug fixes. Please update using the Reallusion Hub. Added: - Support for 3dconnexion (can be toggled on/off in the preference panel).
- Scene Manager now supports reordering with drag-and-drop.
Fixed: - Importing a character with special characters in the naming of its bones will cause a crash in the application.
- Linking a lens flare to a spotlight, and pressing the Modify > Link ("...") button will cause a crash in the application.
- Eyeballs and eyebrows of certain Humanoid characters drift away when imported into CC 4 and iClone 8. Feedback Tracker
- Duplicating a character with motion, breaking it's clip into two segments, and joining the latter clip segment with the former causes an error for the character.
- Application crashes when certain FBX files are imported as props and applied with FBX motions.
- Props with Transform keys fail to carry animation when they are exported in FBX. Feedback Tracker
- Certain FBX can not read Characterization profiles made in 3DXchange.
- Error as a result of saving a CC character as a project in iClone 8 that was rescaled in iClone 7. Feedback Tracker
- Axial errors occur for FBX motion files exported from iClone there were originally imported from Motion Builder via Motion File Import.
- Character spring effects recorded in Motion Director may be missing or experience juddering if the scene is heavy and the FPS drops too low.
- Replacing the character removes sound clips. Feedback Tracker
- Applying iMotionPlus containing voice onto characters and reimporting the saved project, degrades the sound quality while increasing its volume.
- Activating Proportion > Adjusting Full Body scale for an old Standard character with body resized does not keep individual scales for different body parts.
- Applying Flatten All Layers on multi-selected clips will remove some random clips. Feedback Tracker
- Error in the Transform track after executing Insert Frame.
- Error in the Transform track after executing Delete Range.
- CPU threads over 50 will cause motion-related functions to lose effect like applying motion, modifying motion, etc. Feedback Tracker 1, Feedback Tracker 2
- Unable to use the Curve Editor to change the character's Path Position curve from non-linear to linear under the influence of Pick Path. Feedback Tracker
- The camera in the toolbar needs to maintain its start position when Motion Director starts and stops.
- Skin color can be baked to the Diffuse map when Skin Color is deactivated.
- Activating subdivisions on the eyeballs and turning the head will cause a delay in the motion of the eyeball's reflective highlights.
- The facial slider parameter cannot be adjusted with the mouse wheel, up/down arrow keys, and page up/down keys.
- If Motion Director does not have data, and Add Macro is launched in Replay mode, then the Add button is disabled.
- After using waypoints to move the character and when two waypoints are close to each other, the viewport does not show the waypoint, however, the character continues to move in its direction.
- Flatten All Motion with Constraints has no effect on props.
- Applying DRM motion to the characters, saving the rlPose using Content Manager, and applying the pose makes a blocking message appear.
- Opening the application without launching Motion Director, deploying two characters with iMD applied on either one, and using Ctrl+R leads to a lack of data for the Speed info.
- Unexpected reflective artefacts exist for videos exported from certain projects.
- Using F10 to preview a particle project causes visual discrepancies with the particle effects in the viewport.
- Application crashes when rendering video with physical simulation of certain hair. Feedback Tracker 1, Feedback Tracker 2, Feedback Tracker 3
- The Content Manager initializes failed on a weak internet connection.
