kiruxa.elistratov (5/15/2022)
Hi, I have a similar problem. But CC4 works fine for me, and Iclone 8 gives an error at startup that there is no Internet connection, but how is this possible? If the Internet works fine. Running as administrator does not helpI was getting the same "no internet connection" error. I believe that was not the internet, but the CMS server trying to connect to the database, but fails for [I assume] lack of permissions.
Just to make sure, I have launched both programs today, and the CMS has worked in both, so it wasn't a 1-time fluke. In your case, if CC4 works, but IC8 doesn't, then it must be something else indeed. Over here, I was having the same issue with both. Running as admin has solved it for me, but chances are you are experiencing something else there.
On the other hand, IC8 claims to build a morph slider cache when launched, which takes a while longer, and it claims it is a 1-time thing. However, it appears to do it every time, which is not right. I am also having 3D mouse issues with IC8 that I don't have in CC4, which I have posted on another thread here.
These programs have just been released, so I guess it's expected to have bugs that will be resolved over time. Soon, I hope.
