thanks for that very helpful tutorial.
I had given up on using the path as it's fairly useless if you can't detach the character or prop without it jumping back to the origin.
I have used the 'attach to dummy' method, which works ok on props. But it can make characters behave unrealistically as they turn etc.
So I've gone back to transform with key frames in between to keep the character in check.
But this is a good work around a known problem that RL should have rectified many versions ago. I do not understand why RL hasn't addressed such an important issue.
I won't be in a position to upgrade to iC8 for any time in the foreseeable future, so even if this is addressed in iC8, I will be stuck with it for a while yet. So this provides me a workaround to an ongoing frustrating flaw with iClone. Thanks again!
_________________________________________________________
