AMD processors are fine.
Intel and AMD processors are equally good quality processors.
What you need to look at here is the power of the processor, not the brand.
You can buy whichever brand of processor your budget is sufficient for the most powerful series.
The only problem is that there is no embedded graphics card, except for the G series.
If your video card is broken, you will not be able to turn on your computer until you install a video card, as you do not have a built-in video card.
Your computer looks fine for normal system requirements.
I can even say that it is higher level than the standard features. Buying a more powerful computer saves you time.
It is important how many programs you open at the same time.
When I opened iClone and Unreal Engine at the same time, I had no problem working, but I felt that my computer was struggling.
I was also having freezing issues with loaded scenes.
(with 32gb of RAM)I realized that when I increased the amount of ram to 64gb, I worked more comfortably.
Although the ram seems to be sufficient, I definitely think it should be at least 32gb.
But I don't think it will be a problem to start with, you can buy and install these parts later, just make sure your motherboard supports it.
The only problem is if you want to make 64gb in the future, your other RAMs will be wasted.
There are definitely better processors, the core count seems low, but it depends on your budget.
Whatever system features you write here, there is definitely something better
To summarize briefly, if your budget is sufficient for this system, you can work comfortably.
However, if you want a high-level advice, the RAM should be 32GB.
If you want a higher level, I think your processor should be at least 12 cores and RAM 64GB.
Of course, while I am writing these, I run at least 2, at most 4 programs on my computer at the same time.
Therefore, the comments of friends who only work with iClone may be more important.
2 Years Ago by
yepkoo
