[SOLVED] I just forgot to add the Default slot in Animation Blueprint
killl me! Leaving the solution just in case anyone has the same issue in the future.
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------[ORIGINAL POST]
Hi guys! After playing several hours trying to fix this issue with no avail, I'm posting this here just in case someone can figure it out.
I have a custom character created in CC3 and have exported/imported it with the following options:
After importing everything into unreal, using the ThirdPerson template, I have done an animation blueprint retargeting using as target the imported character from CC3.
This works great and I have my character walking/running without any issue in the level. However, when I try to play some animations created for UE4 default mannequin, they do not play correctly.
When I retarget the animations to my character, they play without any issue in the animation preview. However, when I try to play an animaton montage in game (just a small setup based on Input Left mouse click -> Play Anim Montage), it seems there are issues with the root motion or similar and they do not play correctly. Here's an example:
This happens when I use both in place & root motion animations.
Has anyone faced this issue before? Any idea what might be happening?
Animations from original template work as expected (even some custom ones such walk & run added as blendspace in animation blueprint as shown in the video) but not the ones using anim. montages.
3 Years Ago by
sikiruikhun
