ApplebiteMedia
ApplebiteMedia
Visits: 34.9K
I started a new character using another character as a base. The problem is... that character had a large package area. When nude it does not look all that large however with this new uniform, I need to remove this as he looks like he took viagra and it's not going down. This morph has been baked so I am not sure if I am stuck with this or not. I suppose I should just create a base for the male toons. It's been a while and there were a LOT of morphing going on to get these. Not sure I remember the steps I used. [Image Removed By Moderator]As you can see, the nude base is nothing near the extension of the uniform. Is there any way to remove this morph? Maybe in blender? Sculpt it down? Maybe make a reverse morph? Use this as the base and a stock figure as the outcome? I really do not want to try to recreate this character from scratch Thanks in advance.
Graphic Design, PHP Programming, More - Applebite Media (www.applebitemedia.com)
3 Years Ago by
Last Active: 3 hours ago
Posts: 5.7K,
Visits: 26.4K
Have you tried to reduce the bulge using Edit Mesh? It may be possible to adjust it sufficiently with the move and/or scale tools.
Last Active: 5 hours ago
Visits: 60.6K
If you know what the original morph was, you can apply a negative number in the morph box. So just type "-100" into the box to reverse a morph completely.
ApplebiteMedia
ApplebiteMedia
Visits: 34.9K
Hi Gerry, I did try that. However I was not good or successful as it kept a poker that would not reduce. Rampa, I thought of that but didn't know if it would work. LOL. I will give that a shot. Thanks. EDIT: That did it Rampa!!! Awesome! I did have to remove and re-apply the clothing afterward to get it all out but it is gone. Thanks Again!!!
3 Years Ago by
ApplebiteMedia
