if the mocap file is a bvh text file, you can manually edit the speed in the text with notepad - just look for the speed and change it - the bvh text format is relatively plain english - I used to do this all the time to convert super high res mocap to iclone speeds.
if the mocap file is encrypted - then you are at the mercy of the tools the developer that encrypted it gave you.
solution - if you can export the file to bvh text, then do so, edit in notepad, and re-import.
( it's been a while since i've done this, but if I recall - the format is sometimes referred to bvh ascii - for the plain english version - once there you'll notice a header of base parameters - look for the one relative to speed ( i forgot what it's called but it will likely have a "60" next to it - also a fun trick to do extreme slows and speed ups since that field accepts almost any value you give it without error. )
"To define Tao is to defile it" - Lao Tzu
3 Years Ago by
planetstardragon
