I don't know if this helps you, but once you've created your AccuLips clip, you can right-click on it in the timeline and select Set Speed.
In the popup dialog that appears you can the set the playback speed as a percentage.
This will affect the speech sound as well, so it's only useful for doing adjustments after which you should set the speed back to 100%.
