Routine "Failed to Load the File" eror when trying to apply various Playset-Assassins content
Posted By kelbyvp 3 Years Ago
Routine "Failed to Load the File" eror when trying to apply various...
kelbyvp
kelbyvp
Senior Member (433 reputation)Senior Member (433 reputation)Senior Member (433 reputation)Senior Member (433 reputation)Senior Member (433 reputation)Senior Member (433 reputation)Senior Member (433 reputation)Senior Member (433 reputation)Senior Member (433 reputation)
Posts: 50, Visits: 539
I've had no end of problems with the Playset-Assassins pack.  The cloaks and hoods routinely give me a "Failed to Load the File" error when I try to apply to a character.  Then, Smart Gallery will often show the exclamation point in the triangle for that particular asset, so I will tell it to re-install from the server, which it does.  But then it gives me the same "Failed to Load the File" problem and the cycle repeats.
I have tried uninstalling and reinstalling the Assassins playset, but I keep having the same problem.
Other packs seem to work fine.
toystorylab
toystorylab
Distinguished Member (15.7K reputation)Distinguished Member (15.7K reputation)Distinguished Member (15.7K reputation)Distinguished Member (15.7K reputation)Distinguished Member (15.7K reputation)Distinguished Member (15.7K reputation)Distinguished Member (15.7K reputation)Distinguished Member (15.7K reputation)Distinguished Member (15.7K reputation)
Last Active: 3 hours ago
Posts: 4.4K, Visits: 28.8K
Strange...
I just tested and was able to load Hoods & Cloaks A-F without issues.
https://forum.reallusion.com/uploads/images/663ec33b-7635-4f94-a17a-b06f.png
kelbyvp
kelbyvp
Weird.  Sometimes it has worked for me, and sometimes it doesn't.  Right now, it fails every time.  Not sure what I'm doing wrong.
Alvin (RL)
Alvin (RL)
Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)Senior Member (254 reputation)
Group: Moderators
Posts: 39, Visits: 638
Hello kelbyvp,
Do you still have this problem now?
If so, please contact Technical Support through the following link, because we cannot reproduce this problem, and we need you to provide some system information for us to check the cause of the problem.
Thank you.
Alvin
3 Years Ago by Alvin (RL)
kelbyvp
kelbyvp
Hi, Alvin,
Yes, I still have the problem.  But your link doesn't work.  I get a page not found error.
Thanks.
Alvin (RL)
Alvin (RL)
Group: Moderators
Hi kelbyvp,
Smart Gallery released version 1.3 yesterday.
Please update to the latest version through Reallusion Hub to check if the problem still exists, if yes, please contact Technical Support through the link below:
Thanks.
Alvin
Posts: 15.7K, Visits: 30.5K
For me, the Hub still has Smart Gallery v1.2 at the moment.
kelbyvp
kelbyvp
Hi Alvin,
Unfortunately, I can't install anything through Reallusion Hub.  Anytime I try, I get this error:
I have had this problem for some time.
I tried downloading Smart Gallery again from this link:
https://www.reallusion.com/smartgallery/
but I get an error saying that the version I already have installed is newer than the version in the link.
Other suggestions?
Alvin (RL)
Alvin (RL)
Group: Moderators
Hi kelbyvp,
I think there are some special abnormalities in your system environment.
I would suggest you to contact Technical Support and attach this screenshot.
Their reply usually doesn’t take too long and can provide some methods to help you solve the problem.
If necessary, you may need to provide some system information.
Thanks.
Alvin
kelbyvp
kelbyvp
For anyone else who runs into this problem of not being able to install anything from the Reallusion Hub, the Reallusion team did a nice job of identifying the issue.  The issue is that Windows Security's Ransomeware Protection has a "controlled folder access" which, if on, prevents Reallusion Hub from updating software.  It seems to think it's ransomware.  Turning off controlled folder access allows Reallusion Hub to update.  I like to keep Controlled Folder Access on, but for now, I guess I'll have to temporarily turn it off whenever updating Reallusion software.  I'm sure they'll figure out a solution eventually.
