johnschneider066
johnschneider066
Visits: 529
To have two characters walking side by side, can they use the same path or do you suggest two parallel paths?
Last Active: 10 hours ago
Posts: 4.8K,
Visits: 16.4K
I've had good results with one path and attaching a Dummy prop to the path. Then linking the avatars to that Dummy prop. You'll need to tweak the speed of the walks for each avatar and the speed that the dummy moves along the path but that has worked good for me.
3 Years Ago by
mark
Posts: 4.8K,
Visits: 16.4K
In case you are still interested here's a quick tutorial on my down and dirty technique for getting two avatar's to walk side by side using one path.
johnschneider066
johnschneider066
Visits: 529
That’s awesome! Can’t wait to try it myself now. Thank you so much!
Posts: 4.8K,
Visits: 16.4K
Another quick experiment with two different-sized avatar's on the same Path. Still have foot-sliding but I guess I've seen worse...
johnschneider066
johnschneider066
Visits: 529
Thank you so much. Got it now. Used the dummie and it worked great! Saves a lot f time too.
Posts: 4.8K,
Visits: 16.4K
