CYBL (9/14/2021)
How do I remove these two elements from STAGE MODE so I can use my project with MotionLive2D in a live stream without having to do some crazy cropping in my streaming application?
1. Bounding box / Render Area (Not required when using window capture
2. The root "crosshairs"
Hi,
1. You can press F12 as a full-screen mode which will be hidden.
2. The Root crosshair, you could press Ctrl + A to disable the gizmo.
