Problem with external editor
Posted By apyorick1 3 Years Ago
apyorick1
apyorick1
Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)
Posts: 65, Visits: 168
Just recently, when I try to send something to the external editor, the editor shows an error/failed message: no such file or folder found. However, the folder and file are indeed there if I look and I can actually drag the image from the CTA4Temp file into the editor, edit it and it updates as usual in the CTA4 program. There seems to be a pathway issue? I've tried two different image editors with the same problem. Any help appreciated!
apyorick1
apyorick1
Further to this - I've found that if the item has more than one word in its name (for example "basket of shells") the editor is looking for three different files; "basket", "of" and "shells" which of course it doesn't find. However, if it only has one word in its name (such as "boat") it will find it. I've never run into this before a few days ago. Guess I'll have to make sure everything I use from now on has one word only in its name unless (hopefully) someone can help me here.
