Diffuse color (material settings) is not bakes on the diffuse map at export
Posted By praxis_labs 3 Years Ago
Diffuse color (material settings) is not bakes on the diffuse map at...
praxis_labs
praxis_labs
Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)
Posts: 15, Visits: 389
I have adjusted the color of various parts of my model using the Diffuse color for the material settings tab. When i export my Unity 3D Fbx its not getting baked into the diffuse map.  Can I get some help in understanding better how to do that?
Below you can see the diffuse map is black and white and I'm adding color to the shirt using the Diffuse color picker box.  It exports the diffuse map as is , just black and white.
https://forum.reallusion.com/uploads/images/2e0a1815-5107-4adb-b472-d55e.png
3 Years Ago by iuliiii
praxis_labs
praxis_labs
anyone would be able to chime in?
michaelrbarton
michaelrbarton
Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)
Posts: 952, Visits: 11.0K
I don't know that much about Unity. Did you try and save the textures in a folder before exporting to Unity?
Did you unload Appearance Editor before exporting to Unity? Because it does gray out if you don't unload
Appearance Editor.https://forum.reallusion.com/uploads/images/375786e2-b56c-4bf3-9883-90b3.jpg
michaelrbarton
michaelrbarton
https://forum.reallusion.com/uploads/images/8e8e142b-a6d1-4d5d-9a78-4583.bmphttps://forum.reallusion.com/uploads/images/e788a753-15da-439a-a5c7-4c5e.bmphttps://forum.reallusion.com/uploads/images/43cb5a76-1286-4c9d-a2a0-ae52.bmpIt looks like you are not using PBR shader. You must be using the Traditional shader, because it shows Reflection and Specular.
I must have misclicked, because I only wanted 1 photo not 3.
3 Years Ago by michaelrbarton
wetcircuit
wetcircuit
Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)
Posts: 44, Visits: 7.4K
That color is not editing the texture map.
Diffuse Color or Albedo Color is an independent setting. It's usually multiplied with the albedo texture.
The equivalent setting in Unity's standard shader is marked with an arrow:
https://forum.reallusion.com/uploads/images/0867f5ed-28dc-4e80-ba23-41a3.png
praxis_labs
praxis_labs
Thanks so much for your answer @wetcircuit  I work with a dif type of shader. Ideally i'd like my maps to have the Diffuse color channel baked before export.
What is the purpose of a Diffuse color setting in CC3+ if it cant be baked or exported ?   or can it be?
dan_422114
dan_422114
Junior Member (188 reputation)Junior Member (188 reputation)Junior Member (188 reputation)Junior Member (188 reputation)Junior Member (188 reputation)Junior Member (188 reputation)Junior Member (188 reputation)Junior Member (188 reputation)Junior Member (188 reputation)
Posts: 16, Visits: 249
+1 I expected it to be baked, especially when I use instalod to bake to a single texture/material
Last Active: 16 hours ago
Posts: 15.7K, Visits: 30.5K
For PBR material it is better to adjust the Diffuse channel texture.
The Diffuse Color is a holdover from legacy ways to do materials, as it also works when there is no Diffuse texture at all.
dan_422114
dan_422114
animagic (9/24/2021)
Small disagree, adjusting the diffuse is potentially destructive (once you multiply by black, there is no going back!) also only works if the textures are embedded.
Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)
Posts: 5.0K, Visits: 15.9K
That is an interesting question. I do not expect it to be baked on export and original texture should not be destroyed, but the Diffuse color should be properly "routed".
You guys who work with Unity may want to address this question to Victor.
Victor's Unity thread:  https://forum.reallusion.com/FindPost488356.aspx
Same thing is actually happening when exported to Blender. CC Diffuse color ended up as a Viewport Display color in Blender w00t.
But that color could be easily Multiplied with the texture using a couple of extra nodes in shader (same way as it is done in CC).
Victor's Blender thread: https://forum.reallusion.com/FindPost475005.aspx
3 Years Ago by 4u2ges
