bentway23
bentway23
Visits: 144
How can this be done? The closest thing I've found to a guide/tutorial involves going through Blender, but theoretically an .fbx should be able to be used directly (as in Unreal), correct?
Wonder Nexus 3D
Wonder Nexus 3D
Visits: 110
Heya! Did you find an answer to this? I am mucking about in the rokoko studio and i have this pre-made motion capture that also has the face capture included. So i went to the exporter button in the bottom right and when it exports it exports it as two files, the body motions and the face motions seperate. I then imported the body motion into 3DX change 7 and then used the apply to iclone 7 button. Work a charm. But how does one now do the same for the face motions??
Thank you
Last Active: 5 hours ago
Posts: 9.1K,
Can't be done - apples to oranges. Facial animation in iClone is morph based. The FBX in Rokoko would have to match up to this and would require someone to write software to do this (so, I guess it CAN be done if you want to write some code - my own coding days are LONG behind me).
bentway23
bentway23
Visits: 144
The answer to this is the same answer to 99% of questions about iClone: no, unless you give Reallusion another couple-hundred dollars for yet another add-on (and even then it won't work with the Rokoko suit, just their own stuff). The only way to get face capture into iClone is through iClone's own iPhone app--which means purchasing both the motion live plugin and the face model for it.
