How to Merge/Join 2 expressions clips in One Editable CLIP :)
Posted By oldnewusa 3 Years Ago
oldnewusa
oldnewusa
Senior Member (260 reputation)Senior Member (260 reputation)Senior Member (260 reputation)Senior Member (260 reputation)Senior Member (260 reputation)Senior Member (260 reputation)Senior Member (260 reputation)Senior Member (260 reputation)Senior Member (260 reputation)
Posts: 33, Visits: 295
Yeah i know its Iclone. But i hope i just cant find this possibility and its somwwhere hidden... I have 2 different expressions CLIPs both are near, 1st then 2th , and there is no big Deal i just want to ADD EYEBALL rotation , normally
Motion clips we can join/merge , i cant find option to join Expressions Clips... Obviously nothings change after few months. Fortunatelly this my final stage in ICLONE thanks god. I see still > 80 MUSCLE (Morphs) and  still 1 expression Layer.
I know i can save Motion Plus Clip (then load as a 1 expression clip) - but this solution its emmm...  (imagine this with hundreds od clips Wink  )
i know i can run MOTION PUPPET and then use "BLEND" its create for me 1 Expression CLIP  but for god sake i just want JOIN/MERGE 2 clips.
Please again DO NOT  release ICLONE 8 - FIX Iclone 7.
Obviously RESETABLE BUG with Face-key line still not fixed. Use some slider  for example SMILE and later go to MUSCLE TAB , and move Eyeball , your smile goes to 80% , before was 100%. I said few times abt this.
Please tell me WHY ? Im moving a EYE-BALL in FaceKey Tab and this AFFECTS my LIPS morph-slider Sad ? Seriously....
I know iclone 7 self its a cheap tool , you adding knew options, why you cant fix older things/problems?
 Administrator Peter knew about that problem.
MY first months in ICLONE was WOW amazing tool, but after 3 years... Fortunately there is Character Creator 3 and Blender Auto Setup, im about to end using ICLONE , my last project is WIP.
Start listening to the customers.
michaelrbarton
michaelrbarton
Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)
Posts: 952, Visits: 11.0K
You can just collect the clip and save it as a Motion Plus clip. And use it again and again.
You can also edit the Motion Plus clip by adding more expressions to it.
oldnewusa
oldnewusa
im not suprised at the lack of answers.
That above replay is what i've said allready.
Reallusion dont care for customers.
Ascensi
Ascensi
Posts: 247, Visits: 1.8K
This glitch also happens with Edit Motion Layer. Sometimes I move a foot and a hand moves slightly.
Store Page Link
AMD 4.5 GHz 16 Cores  | 128 GB | RTX 4090 | Window11 | Houdini FX 18.5 | Zbrush 2023 | Maya 2014 | Adobe CS6 | Sonar Producer X3 | iC8, CC4 | DTS Master Audio Suite | Perception Neuron 32 Alum Edition | Akeytsu
Last Active: 11 hours ago
Posts: 22.7K, Visits: 35.7K
oldnewusa (8/18/2021)
Hi...
Did you report this in the Feedback Tracker? The best way to get issues fixed or new features implemented is to use the Feedback Tracker.
The tracker is monitored directly by the relevant product teams and you will get feedback from the team there when applicable. In addition, it allows other users to support your request with the most requested suggestions normally getting priority.
If you do wish to use the Feedback Tracker, please click the link below.
http://www.reallusion.com/FeedBackTracker/
Regarding merging expressions, this isn't available in the same way as merging motion clips so using "Collect Clip" is the way to go as already suggested. I know this adds a few extra steps to the process but it is still  an easy way to accomplish what you need.
Ascensi
Ascensi
Hi Peter, I had posted issues around incorrect positioning like this on the FT under a different title because I wasn't sure what was going on, it looks like it is a bug but wasn't sure until now.
https://www.reallusion.com/FeedBackTracker/Issue/Copy-and-paste-joint-position-to-absolute-world-space-position-frames-nearby-conform-with-optional-smoothing
Store Page Link
Ascensi (8/31/2021)
Thanks for using the Feedback Tracker. The issue is under investigation so please keep a check back now and then to see if there are any status updates.
