This has been moving along at the speed of a crippled snail, but things are progressing.
Before getting in to the clip, a few notes.
I have attempted to keep as much of the work involved within the RL 3D animation family, and one of the things that I wanted to do was the creation of the titles without resorting to the collection of title tools that I use in my NLE. For the title I used SketchUp 8, 3DXchange and iClone.
First step to create the text in SketchUp:
Once added the component was exploded to separate the text:
Next step was to select each letter and convert them to individual components within the main one:
Once saved the file was opened in 3DXchange and the back faces removed to reduce poly count:
The individual letters were made Sub-props:
The last step was exporting the text as a prop, with sub-props included, to iClone:
Once in iClone the letters were given a PBR texture:
The next step required adding some dripping blood to the Blend channel:
Once that was complete it was necessary to make some adjustments to the UV settings. For each letter minor changes had to be made to the U tiling value.
The U and V offsets were set at frame 1 and the V offset was adjusted to move the "blood" down each letter at the last frame in the scene:
The final work required adding a dagger, placing it over the letter T and turning the material opacity to 0 at frame 1. Moving along the Timeline keyframes were added for the dagger and the letter T to keep their state. Finally 2 more keyframes were added to change the dagger opacity to 100 and the letter T to 0, giving a blend between the 2:
Last but not least I placed a lightning overlay:
The final result in iClone:
More to follow.
3 Years Ago by
