Kelleytoons (8/12/2021)
Um, what users tell you this?
Honestly, the audio tracks in iClone are just for timing purposes. No serious animator really cares, as they will be adding them later in post production. Yes. They are most useful for timing purposes. After the recording, Acculips can be used on the audio to improve the lipsync. It works well. I believe that is the intent of the software.
The only disadvantage to it is that, because iClone embeds the audio track in a proprietary file format, and because iClone has no audio editing tools of its own, it is not possible to edit the audio track -- say for example to remove background hiss, to alter the pitch, to add echo, or other reasons.
Assembling two different files, rather than using the obvious timing advantage of using the audio recorded in Motion Live, and the need to remove background noise that may have been added in the recording environment, seems, on the surface to be unnecessary.
It is not mentioned in the manual.
It is not referred to in any YT tutorial that I have found.
I never ASSume that I know, if I have not asked. I ask the question *WHY* out of respect for the people here who have mentioned it.
EDIT:
This is a very interesting post --
https://forum.reallusion.com/287837/I-record-my-voice-in-facial-animation-where-does-iClone-store-the-audio-fileIt seems that editing the original audio can be done after all.
I tried it, it works.
"Less clicks good, more clicks bad."
3 Years Ago by
R Ham
