Visits: 4.0K
Hi, I am determined to connect Live Face to Motion Live. I need your help, though. -- Live Face is installed on my iPhone XR. -- It is connected to Motion Live per the Ethernet instructions in the Motion Live Manual. PC and iPhone are on the same domain. https://manual.reallusion.com/Motion_LIVE_Plugin/ENU/Content/iClone_7/Pro_7.0/29_Plug_in/Motion_Live/Connecting_to_LIVE_Face.htm-- The IP Address in Live Face matches the Belkin config, as well as the listing in my Asus router. BUT... Motion Live does not acknowledge the iPhone. The Motion Live Facial "Add Gear" button does nothing. .............................................. I've read every manual I could find. I've tried it with both WIFI and with Ethernet cable. Motion Live just won't see that iPhone. Help.....
"Less clicks good, more clicks bad."
Posts: 9.1K,
Visits: 21.7K
Are you sure you have the right connection written out - it needs :99 at the very end (if you have ANY questions post what you are putting in that connection string so we can make sure it's right).
Visits: 4.0K
Thank you for your reply Mike. I had everything hooked up right, but there were 249 additional reasons why I wasn't connecting. The Live Face Profile made a difference. Duh... Now, at last, I'll figure out how to use this rig. I'll be back... ;-)
