Sculp_Male and Undercut Fade are intersecting.
Transform it instead of Mesh Edit.
Load Undercut Fade fresh and select it.
In Modify panel go to Transform section.
Check Lock Scale XYZ.
Then start adding Up value to Scale X. When you reach ~ 100.7, the patch should be raised enough above Sculp_Male mesh and intersection would be cleared.
You can also scale down Sculp_Male in Morphs section a bit. There are some sliders including Scale Morph.
But honestly, I am not sure if you even need that Sculp_Male cover. Unless you are adding some other patches to cover it at the top.
Oh yeah... and Welcome
3 Years Ago by
