DAZ landscapes?
Posted By gordryd 3 Years Ago
gordryd
gordryd
Posts: 711, Visits: 7.6K
The DAZ "Pacific Northwest Botanica - Bundle" looks better than most of the RL plant materials.  Will this material transfer in via transformer like any other prop?  Or does DAZ have some sort of proprietary format for their trees/plants/ground as well?
Last Active: 3 hours ago
Posts: 9.1K, Visits: 21.8K
It's a good question - I have it but have not gotten around to trying it out.  I'll see if I can check it out in the morning and let you know.
Okay, I had a play with this this morning.  A couple of things to note:
1) The individual trees and shrubs can be brought over just fine.  I'm not sure if they look any better than Speedtrees but the one big advantage they have is you can change the materials on them (which you can not do with Speedtrees).  Here's a scene in iClone where I took the maple tree they provided (with green leaves) and replaced the leaves with my own coloring.  Now, to be fair, Speedtrees comes with enough variance (like fall foliage) to cover most circumstances, but if you need, say, alien stuff or very unusual coloration you're out of luck with Speedtrees.  OTOH, they have no physics (unlike Speedtrees) so you won't get the wonderful look of the branches blowing in the wind (you might try applying some spring stuff to them, but it's above my pay grade).
https://forum.reallusion.com/uploads/images/28dec748-1825-4b8e-80c9-64a6.png
2) No way are you going to use the Ultrascenery system to create the kind of landscape they show in the images.  Oh, you *can* create such things inside of iClone, and they aren't any different than any other items there (so can be exported) but they take a TON of resources and time.  On my machine (which most likely is much better than yours) it took almost 15 minutes just to generate the default NW forest in Daz.  And this was nearly ALL instances (if you aren't familiar, instances inside of Daz don't get exported, so you only get one copy of each tree, for example.  The default NW forest 1 used 500 copies of around 100 trees).  Now, you *can* convert instances into Objects (I have a Daz script which does this and which I use on occasion) but you couldn't even load in such a scene in Daz, let alone export it and use it in iClone.
Even with all the instances it takes freakin' forever to export.  I gave up after two hours of trying to export that default scene above.  So I switched to a much sparser scene (only took 8 minutes to generate and around an hour to export) and... it didn't come into iClone as anything usable.
So the bottom line is this - if you want individual trees and don't mind not having wind FX then, sure, that pack is fine.  Just don't expect that landscape they show.  But, honestly, Speedtrees is SO much better (and you can use the new terrain generator script to do a much better job than this Ultrascenery thing can do).
gordryd
gordryd
Thanks for the detailed answer.
matenn30
matenn30
Posts: 457, Visits: 3.3K
You sell plug-ins. This challenge is also good.
プラグインを売っていますね。この挑戦もいいです。
The forum is an amateur.
フォーラムは素人です。
